Factory Remote start after the fact >
Old 12-05-2007 | 02:13 PM
c_deezy's Avatar
Default Factory Remote start after the fact
Ok here's the deal. I bought a new 07 Sierra HD2500 back around the beginning of September. At the time I thought I could get by without it but now that winter is upon us here in Cleveland I decided I need the remote start. On the build sheet for my truck it says I have the Remote Start Accomodations Package (AP8) so I am assuming it would not be too difficult to retrofit the factory remote start. I called a dealership yesterday and the service guy didn't know if it was possible and so far hasn't seemed to eager to find out and call me back so that's why I'm putting this on here, to try to get the input of somebody that may work at a dealership that can give me a yeah or nay if this is possible. Ideally I would like to get the new 2-way remote start.
http://www.gmaccessorieszone.com/ind..._gmshopb2b_pi1[division_name]=GMC&tx_gmshopb2b_pi1[vehicle_name]=Sierra&tx_gmshopb2b_pi1[year]=2008&tx_gmshopb2b_pi1[sub_product_group]=Remote%20Start&tx_gmshopb2b_pi1[type]=gm
c_deezy is offline
Old 12-05-2007 | 03:06 PM
Tony Montana's Avatar
The BAD Guy
Don't know about the factory one. I did however put a AUTOPAGE RS-1000 alarm in my f-250 and love it. It has a pager that can page you if the alarm goes off up to a mile away. It also has the remote start which works from up to a 1/4 mile away! My wife has a factory remote start on her Mazda and it sucks as far as range goes. I start mine when I am leaving a store or the gym when I am still inside and it reaches no problem. Just thought I would throw that option out there for you to think about.
Tony Montana is offline
Old 12-05-2007 | 03:49 PM
Smitty's Avatar
Call the parts dept. and see if they make a kit for your vehicle. If they do it will be a plug and play deal and should be easy to do.
Smitty is offline
Old 12-05-2007 | 03:50 PM
c-deezy: That looks like the right kit. The factory one is the way to go.
Wannabe
wannabe is offline
Old 12-05-2007 | 04:49 PM
hunster's Avatar
Don't bother with the factory r/s. It won't turn on the heat or defroster!!! Yes the engine will be warm but your azz will still get cold as you scrape the windshield. What engineer designed that piece of crap is shot. The range is another bummer with the factory system. I sell them and have done many in the new truck 03-06 and 07 up with the new lan system. If you have the factory r/s , here is a neat piece to adress the 2 way and range issues. http://www.bypasskit.com/product.asp...XL2230&catid=7
hunster is offline
Old 12-05-2007 | 05:52 PM
Steel Outlawed's Avatar
I have a friend that just had the factory remote start added to his 07 Sierra. He had to call a couple dealerships to find one that would do it, but he got it installed and he said it works great.
I have a 07 2500 Chevy LTZ, and it came with the remote start. Someone mentioned that it does not turn the heat on. Mine turns the heat on high the defroster on high the heated windshield washer fluid on, and the heated seats on high.
Steel Outlawed is offline
Old 12-05-2007 | 09:50 PM
Here is the GM Bulletin. Hope this helps.
Subject: Information On Adding The GM Accessory Remote Star Kit - keywords entry install keyless receiver #PIT4082D - (12/03/2007)
Models: 2007-2008 Cadillac Escalade, ESV, EXT
2007-2008 Chevrolet Avalanche, Silverado, Suburban, Tahoe
2007-2008 GMC Sierra, Yukon, Yukon Denali, Yukon XL, Yukon Denali XL
This PI was superseded to update Recommendation/Instructions. Please discard PIT4082C.
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern:
The following is additional information on adding the GM accessory remote start.
Recommendation/Instructions:
Vehicles must have the extended remote start option RPO (AP8) in order to add the GM accessory remote start kit. This kit is only available on automatic transmission models. Every step of the instruction sheet needs to be followed exactly in order for the remote start to operate properly. Here is a brief summary of what needs to be performed.
The BCM needs to be programmed for remote start by contacting the Techline customer support center @ 1-800-828-6860 and having them add the remote start function to the VIN number so the BCM can be reprogrammed by TIS2WEB. After reprogramming the BCM, the vehicle will need to be shut off for 1 minute and then restraints ID will need to be setup by using the "Set up SDM primary key in the BCM" under module setup category in the BCM.
Note: Once the remote start option is added to VIN at Techline, the option will always be available even if the BCM is replaced or re-programmed at a later date.
The instructions state that the BPP brake sensor will need to be re-calibrated. This is not true because the 2007 Full Size Trucks And Utilities are not equipped with a BPP sensor.
The Theft Deterrent Module will need to be SPS programmed with the remote start option selected.
Note: Please select TDM in the controller list and not VTD relearn when re-programming the TDM
Clear all codes in all the modules on the vehicle.
Program the new remotes (supplied in the kit) to the Remote Control Door Lock Receiver
Installation Complete
Troubleshooting: Remote Start Inoperative:
If the vehicle is equipped with RPO UK3 Steering Wheel Controls with the Drivers Information Center (DIC), make sure remote start option is turned on in the DIC.
Make sure the Remote Control Door Lock Receiver is calibrated for the remote start option. Most vehicles with the RPO (AP8) should already be programmed for remote start.
Make sure the vehicle has adequate fuel (above a 1/4 of a tank).
Make sure there are no PCM diagnostic trouble codes.
Check any of the disable conditions listed in Document ID# 1689813 In SI2000.
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
JMAASKE is offline
Old 12-05-2007 | 10:12 PM
c_deezy's Avatar
Thanks for the input guys, it really helps.
Steel - Did you get the 2-way or the regular remote start?
c_deezy is offline
Old 12-06-2007 | 09:47 AM
c_deezy's Avatar
Thanks for the bulletin JMAASKE, when I called the dealership again and talked to the service department they were like 'yeah we don't do that', until I made it clear I wanted the factory remote start installed.
Then I got it again when they transferred me to the parts department and they were like 'Two way remote start? What the hell are you talking about?'. But they are getting the parts in this afternoon and are supposed to call back and let me know if its what I want or not. Really the price wasn't too bad, $195 for the fobs, $130 to install/reprogram.
c_deezy is offline
Old 12-06-2007 | 10:09 AM
You can sell your old original remotes on ebay or whatever and get some of that money back.
JMAASKE is offline
