Tow vehicles
Old 08-04-2008 | 12:07 PM
  #161
rjr
Judging by the way the front end appears to be pointing skyward probably has WAY too much tongue weight.
rjr is offline
Old 08-04-2008 | 01:50 PM
  #162
jonyb's Avatar
Originally Posted by jmeng
Thanks man, truck really looks good. Am thinking about buying a 250/350 this winter, already debating how high I want to go with it.
Something to remember is that the 04 and down have a SFA, so the lifting is easier and cheaper, but are a little harder to drive. Also, 8" is the limit on those before you start needing new driveshafts and brake lines. I think a 6" with 35's and 20's is about perfect.
jonyb is offline
  #163
Registered User
Tongue weight? I'd be more concerned with exceeding towing capacity. By a bunch.
Chris Sunkin is offline
Old 08-04-2008 | 02:07 PM
  #164
About what I was thinking. 38's look good but probably a little much for a daily driver for me anyway. 35s and 4 - 6" of lift would probably make me happy. Def want 05 or newer for smoother ride.
jmeng is offline
Old 08-04-2008 | 08:26 PM
  #165
he he, Obviously unfimiliar with the capabilities of the old military cucv.
This ain't no civilian K-5.... Can you say 1-ton?
LLLiiiikkee Aaa Rroccckkk
the saggage is due to the ultra flexy Offroad Design Inc rear shackle flip kit. That and the short wheelbase, while maybe not the best for towing, create dominance at the offroad parks. I have yet to meet a trail I can't conquer. Being able to tow my lil scarab (with ease) is just a bonus.
la-zdunck is offline
Old 08-05-2008 | 09:54 PM
  #166
Cool looking old blazer. Military spec or not, I sure as heck wouldnt pull that boat with it. Ultra flexy is what you will be when you are getting bent over by the insurance companies if you have a wreck. Maybe they will cut you slack if you tell them its not a civilian blazer.
That old scarab probably weighs in at 10-11k lbs or better with that steel trailer. You can put 1 ton parts on a 1/2 ton, but its still a half ton truck on paper. I used to tow a single engine 26 scarab with a K5 blazer. I had heavier springs, axles, etc. It was a miserable and scary ride on the freeway at 55mph. Ended up trading it in for a 1991 Dodge 2500 club cab cummins truck. WAAAY better towing the boat. Cant imagine pullin that 34 you have.
Like the scarab though, what kind of power you got in it?
SCUBASCARAB is offline
Old 08-06-2008 | 05:00 AM
  #167
here is mine, old 2000 f350 crew cab dually 4x4, 7.3l POWERSTROKE, tuned, open exhaust, k&n. and my Pantera 28.
Panterafreak is offline
Old 08-06-2008 | 06:21 AM
  #168
45sonic's Avatar
2004 F350 diesel lifted 4" with bigger tires. Front hitch, rear airbags, extra trans cooler, upgraded lighting, upgraded rear hitch, pulls a 45 Sonic great.
45sonic is offline
Old 08-06-2008 | 01:54 PM
  #169
Originally Posted by PJDiesel
Good Choice, I too have a Cummins.
Little over kill for my current boat, but you never know what the future holds.......
I don't think it's overkill. The time may come(I hope not though) when you'll be glad you have the dually's stability to keep your boat's trailer from fishtailing. Remember, if that starts to happen, accelerate out of it if you can.
Hot Knots is offline
Old 08-06-2008 | 03:26 PM
  #170
I use a 2006 F250 with a 4" lift and 35" tires to pull my 31' Sonic and it works like a charm.
niceguy is offline
