Repaint Boat Trailer
Old 06-17-2008 | 02:11 PM
Rage's Avatar
Yep. Imron MSDS sheet 2, 3 & 4 as you said, once the activator is added fresh air only. Nasty.
http://www.performancecoatings.dupon...le=DirectLogin
Originally Posted by Chris Sunkin
The only specified respirator for Imron is fresh-air supply. No filters work on cyano. This is why you can't even access information on the product on DuPont's website- they don't want anyone other than professional applicators using it. Body shop supply stores sometimes care but most often don't. they also don't sufficiently warn people about the health hazards of this stuff. If you're using it outside in a well-ventilated area, you will have way less issue.
Rage is offline
Old 06-18-2008 | 08:00 AM
I've been painting 25 years and I can attest to the fact that it does impair your..............Sh*t I forgot what I was saying!
kennyo is offline
Old 06-18-2008 | 06:26 PM
Original manufactures do not clean steel enough. There is still mill scale and oil on the steel surfaces. You will have a better longer lasting finish on a blasted trailer than new. It is well worth the time and effort. Be sure to primer as soon as you can after blasting. You may consider brushing inside rails while spraying to get all the inside corners.
fossil fuel is offline
Old 06-19-2008 | 11:18 PM
PhantomChaos's Avatar
Originally Posted by Rage
Has anyone repainted a trailer? If so how did you go about it or who did you have do it? Cost?
Yep....should be picking it up tomorrow. Some parts had to be reconstructed (the rear piece with the lights in it). Down to the metal and all re-done.....<$5K Everything!
PhantomChaos is offline
Old 06-19-2008 | 11:20 PM
Oh........
www.BearTrailerSports.com
Old 06-20-2008 | 01:33 PM
Jammin''s Avatar
When I'm spraying catalyzed epoxies and polyesters I tell the neighborhood kids to get on in the house .
I friend just did his trailer with Rhinoliner. It looks awesome. He painted the fenders with urethane.
Jammin' is offline
Old 06-24-2008 | 09:53 AM
I't turned out to be around $6K, but I had to have a lot redone. New custom fenders, refabricate the rear frame (where the lights are)......lots of rust to remove.
Attached Thumbnails Repaint Boat Trailer-dsc00785.jpg   Repaint Boat Trailer-dsc00787.jpg   Repaint Boat Trailer-dsc00788.jpg
Old 06-24-2008 | 10:49 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Turned out great Nort.
Sydwayz is offline
Rage
Detailing, Painting, & Fiberglass
15
08-27-2008 03:51 PM
Rage
Nordic
7
06-19-2008 12:07 PM
Dave1972
02-06-2006 11:37 AM
GregP
10-19-2004 11:35 AM
thedonz
10-01-2004 10:57 PM
