-   Trucks, Trailers and Transportation (https://www.offshoreonly.com/forums/trucks-trailers-transportation-159/)
-   -   Aluminumized diesel exhaust (https://www.offshoreonly.com/forums/trucks-trailers-transportation/190190-aluminumized-diesel-exhaust.html)
bigboat28 07-03-2008 10:45 AM
Any put the aluminumized exhaust on a ford 7.3, instead of the stainless? How long did it last? Is it worth the cheaper price?
Sydwayz 07-03-2008 11:37 AM
Have you checked eBay? You ought to be able to pick up the SS kit for less than $400 shipped.
I would not get the Aluminum. My EGTs have gotten up over 1000 degrees F on long steep grades on hot days when towing. 1200-1300 is going to damage any metal (melt), and the aluminum is probably even more susceptible to damage from heat.
JPD Motorsports 07-03-2008 05:17 PM
the galvalum I think it is is what I have on my rig in 5" and can carry the egts with no probs had it on the truck for 5 yrs and it is driven every day rain snow sun no signs of rust/wear even drug the exhaust across a steep incline with no troubles for the truck is lowered.
Jassman 07-03-2008 10:26 PM
I have had many aluminized exhausts on many rigs..no difference in mearsurable egts, does the job on less of a budget..Tips are always SS...
mwdill 07-04-2008 04:35 AM
i believe anything above 1300 starts to do some damage.
Jassman 07-04-2008 06:40 AM
1350 is ok for 1 - 2 minutes...you will see on some of the higher hp programs for 2 -3 seconds programs hitting 1500 -1600 degrees..before the next shift ...very common. Is it something you want to do ll the time.. no...
Some stock trucks will hit 1300 degrees on a steep grade pulling a load..keep that in mind also.
Comanche3Six 07-04-2008 06:40 AM
2 years........works great, looks great.
