Powerslot Cryo's/Hawk SUV's or EBC? >
Old 07-23-2008 | 12:19 PM
Registered User
Originally Posted by Knot 4 Me
My current rotors are warped and glazed from all the heat generated from stoping 8,500lbs. of boat/trailer by themselves.
Save your money and invest in a better working trailer brake setup. (assuming I'm misreading your post and that you have trailer brakes- not just using the truck)
Chris Sunkin is offline
Old 07-23-2008 | 03:19 PM
Knot 4 Me's Avatar
I have four wheel disc brakes on my trailer and when they work, they work great. What happened was on a trip to LOTO late last year the trailer brakes stopped working. I found out the hard way coming down a big incline at an off ramp at Hannibal. I damn near didn't get stopped before hitting the vehicle in front of me at the stop light. Brakes got so hot it smelled like the truck was on fire. I traced the trailer brake problem down to a faulty reverse lockout solenoid and all is good again with the trailer brakes. Since that incident warped the stock rotors, I'm now getting around to fixing the front brakes on the Denali. I only use it as a tow vehicle anymore so there was no hurry to address its brakes. They still work, they just shake bad once you get any heat into them. Pads are fine as far as thickness with only 25K miles on them but they have to be glazed from all the heat. I've never been impressed with the stock brakes from day one with the truck having 20's on it. Just looking for alternatives over stock that might offer better braking with the larger wheel/tire combo and when I tow. Might be a mistake, but yesterday I went ahead and ordered a set of slotted Brembo rotors and some Havk LTS/SUV pads. I'll report back how they work once I get them bedded in. Thanks for all the responses!
Jeff
Knot 4 Me is offline
Old 07-23-2008 | 04:17 PM
Registered User
The Brembo rotors aren't a mistake, but they'll provide you with little if any noticeable benefit.
You really need to change over to EOH on that trailer. Simply put, you got really lucky. At some point, brakes get so hot they become totally useless. If they reach this point, you'll end up with a runaway. Surge brakes need surge to activate them and if you get that long downhill that cooks the truck's brakes, your trailer has no way to activate surge brakes. Plus the EOH is much smoother and reliable. and you can control the trailer independently. Cheap upgrade but worth every nickle.
Old 07-24-2008 | 08:35 AM
Knot 4 Me's Avatar
I've never tried slotted rotors so I thought WTH, might as well see if they make any difference. In the end it only ran me an extra $100 total over going with stock rotors.
I've looked into EOH. I agree surge alone is not the best route to go. In my case of losing the trailer brakes EOH would not have made a difference as the lockout solenoid was either bypassing fluid back into the master cylinder or blocking the flow of fluid back to the calipers. This would have occured whether the surge actuator was deploying the brakes or the EOH unit was deploying them. Scary stuff for sure as I've never had this happen in 10 + years of boat towing. I always make sure my equipment is working properly before towing and they worked fine when I retrieved the boat from my slip for the trip down. I just about put a load into my huggies when I felt the boat/trailer pushing me forward under heavy braking!!!
Old 07-24-2008 | 09:05 AM
EOH gets rid of the lockout solenoid.
"Cheap" is a relative term IMHO but there's no question that changing to EOH is a worthy investment.
handfulz28 is offline
Old 07-24-2008 | 09:22 AM
Knot 4 Me's Avatar
In my best Johnny Carson voice, "I, I did not know that. That is wild, wacky stuff!" I will definitely look harder into EOH then as I'm not a fan of the lockout.
Old 09-03-2008 | 10:08 AM
Knot 4 Me's Avatar
Update. Thought I would post my experiences with the route I took. Added Brembo Sport slotted rotors and Hawk LTS/SUV pads to the front of my '06 Yukon XL Denali. Man, what a difference. I would highly recommend this upgrade to anyone looking to get better braking performance over stock. The only PITA in the swap was GM using torx bolts on the calipers. Took a T-55 and the biggest I had was a T-50. BTW, anyone know what the torque setting is for those caliper bolts? I just took a guess. They were a mother to break loose.
Old 09-03-2008 | 10:54 AM
Registered User
Let us know on pad life. My experience with slotted rotors was better braking but they really gobbled up pads.
Old 09-03-2008 | 11:10 AM
Knot 4 Me's Avatar
Will do. My guess is 99% of the feel good of the new brakes is the pads alone. The non-slotted Brembos, which cost the same as about any other standard rotor for this application, would have probably been fine. I do like the Brembo rotors and their finish. After bedding the pads in and letting them cool, I made a couple of "panic" stops. Compared to the factory junk, these pads make you feel like you are going through the windshield.
Old 09-03-2008 | 11:42 AM
Can you convert surge brakes with drums to electric over hydraulic?
RonS is offline
