Best rear shocks for towing (08 Chevy hd)
Firestone Air Bags, way to go. They will really SMOOTH out the ride. I run at 15 psi empty and 45-50 psi when towing. I have 53000 on my 3/4 ton Avalanche and my bilsteins are fine empty but the air bags made all the differnce.
Wannabe
Wannabe
I got the "bounce" too. I mention it in my trailer redo thread.
my first thought is bags 'cause then they will be there, and I know I'll want them anyway towing 13K boat package.
my '06 hasn't turned 6K miles yet and the unloaded or light towing ride is acceptable, so I hate to throw the stockers away just yet...
bags...
bags...
honestly... comming from a desert racing background, bilsteins are great shocks but for something else to try... maybe rancho rs9000's with rezzies, they are adjustable (you can get an option to be able to adjust them in cab too) so you can stiffen them up when you tow. you may also want to consider soething more upscale and servicable (were you can adjust valving, change fluid and adjust the nitrogen level) like kings, high end bilstiens or fox. also the ones with the remote rezzies keep the nitrogen seperate in a bladder instead of mixing it in the oil. have you considered double shocking the rear and going with softer valved shocks to decrease their individual workload??
I went to Edlebrock shocks on my (2000) Ford Dually. I've got full leaf-spring suspension front and rear, and Firestone Airbags on the rear. The shocks probably have 15,000 miles on them, and 10,000 of them are towing.
The Edlebrocks REALLY improved my ride, towing and non-towing.
If you are wearing out rear shocks, its time to add a set of rear Airbags. The difference will be night and day. The Airbags essentially become an adjustable "anti-sway bar" which can also improve your non-towing handling, including reduced body roll, and keeping the outer rear end planted in turns rather than allowing the suspension to dip.
The edelbrock shocks ride smoother than any shock I have ever used on the rear of my trucks on 2 lane roads and highway,its just on the concrete exspressway they suck as bad as the stockers. I'm going to re-think the air bags though,maybe they will be my solution. A friend of mine will be towing his boat that is slightly bigger than mine with his 06 duramax down the same stretch of highway friday and he has already changed his shocks to bilsteins,if he says it rode ok then I'm just going to ditch these edelbrock shocks and get another pair,Smitty
The edelbrocks seem to ride smoother than I remember the bilsteins riding on the country 2 lanes and blacktop highway,its just they are not much better than my old shocks on the concrete. I might end up trying some airbags though after hearing everyones responses,thanks for your input,Smitty
Registered User
The Bilsteins are nice shocks. I put them on the girls FJ and the difference was night and day. On both of my jeeps I used Pro-comp MX-6's. They are adjustable (although I seldom adjusted them). They are very nice shocks as well, way better than the rs 9000 ranchos. If you do get rancho adjustables stay away from the in cab controller unless you like fixing leaks.
Some of the ford f-250's are running Rancho shocks, I have a set of their 9000's I think, they were adjustable, ran them on a full size Blazer and they have lasted well over 100k miles, they are still on there and they came with a lifetime warranty if I remember correctly.
Only problem is I have had to replace the urethane bushings 3 times
What are you usung for oil?? I have had really good sucess with amsoil atf fluid....
I been using a synthetic shock oil for the fox shocks I rebuild that I get from HPE (a snowmobile supply co),I think its about 5 weight around 8$ a qt,this is for snowmobiles though it does look a awful lot like atf,Smitty
