-   Trucks, Trailers and Transportation (https://www.offshoreonly.com/forums/trucks-trailers-transportation-159/)
-   -   EZ-Lube Spindles (https://www.offshoreonly.com/forums/trucks-trailers-transportation/196998-ez-lube-spindles.html)
Prater 10-09-2008 11:41 PM
EZ-Lube Spindles
My three new axles are ready to install. They have the Dexter EZ-Lube spindle and I was wondering if anyone else uses that spindle on their boat trailer? if so can you use a Bearing Buddy with them?
http://dexteraxle.com/e_z_lube_system
27daytona 10-10-2008 12:25 AM
I have these hubs on my 48' enclosed car trailer, nice hubs but I do not think that they are designed to be submersed in water. Doug
Prater 10-10-2008 12:34 AM
They are for use were the axles are immersed in water, that is one of their strong points according to Dexter. I picked these up at the Dexter Factory in Oklahoma today and talked about the Dexter brake system also. I think I will go that route instead of Kodiak. I wont ever have the trailer in salt anyways.
cig1988 10-10-2008 03:46 AM
Have them on my trailer that dunks in salt water with no problems. Bearing buddies would be a waste of money. While grease is pumped on the small end of the spindle it will force into the large side and back into the small side of the spindle.
happy hours 10-10-2008 06:44 AM
I have them on my trailer (Owens& Sons) for about 5 yrs now and dunk is salt about once a week. IMHO they are way better then bearing buddies because you pump the grease into both bearings rater then just fill the cavity on the outer bearing. You can actually pump loads of grease thru to cycle out the grease if you want. (I still take apart every now and then to inspect and all that)
Chris Sunkin 10-10-2008 06:53 AM
I think Doug might be thinking of oil-bath hubs, as you would find on medium and HD trucks & trailers.
You can use bearing buddies on the EZ-Lube's but I'd prefer these- http://www.airtighthubs.com/products-sport.php
The object of either is to prevent water from being drawn in when the warm bearing hits the cold water and the internal volume contracts.
Here are instructions specific to using the Airtite with drilled spindles, including pics- http://www.airtighthubs.com/PDF%20fi...nceandOper.pdf
Additionally, the Airtite has a far superior backside seal.
RaggedEdge 10-10-2008 07:21 AM
I have them on my trailer, Performance Trailer, and my understanding is that you should not use bearing buddys. The principal of the E-Z lubes is to push the grease thru the center of the spindle, thru the rear/inner bearing, thru the front/outer bearing and out of the assembly. Replacing the old grease with new and pushing the old out. Makes sense that the bearing buddy would screw up/prevent this process. The owner of Performance is a friend and the info is from him, I would think he would be a good source, he uses Dexter E-Z lubes on the trailers he builds. There is some info on these on the Dexter site that shows how they are designed to work.
One way to help keep water from being sucked in is to simply let things, bearings etc, cool down before you launch.
Chris Sunkin 10-10-2008 07:33 AM
Go to the second link I posted and you'll see how drilled axles work.
They don't push grease out the back, the circulate it from the rear, foward, through the races. BB's will not help or hinder the operation in any way- they simply provide positive pressure inside the hub cavity.
Dock Holiday 10-10-2008 08:30 AM
Myco uses the EZ Lube.
Need I say more?
handfulz28 10-10-2008 08:38 AM
Not sure if you meant BBs or Airtight's system, but EZ-Lube/Posi Lube were designed to do away with Bearing Buddies. Adding A BB would negate the benefit of the EZ Lube design.
Prater 10-10-2008 11:00 AM
I will pass on the bearing protectors and just use the EZ-Lube hubs.
Here is the response from Buddy bearing rep.
The Bearing BuddyR can be used with the EZ-Lube spindles, however, if
the grease fitting on the spindle you must remove it before installing
the Bearing Buddy. You must also check to see if there is a release
valve at the inner side of the spindle, if there is you need to seal it
with a #10 screw.
CR/customer service
Chris Sunkin 10-10-2008 12:10 PM
Two completely different systems. The only thing they have in common is bearings & grease. EZ lube just makes it easier to repack bearings. New grease in, old grease out. The bearing buddy uses grease to apply positive pressure to your hub, eliminating the vacuum effect when hot hubs hit cold water and the reduced temp (volume) causes a vacuum which draws water into the hub thru the seal.
handfulz28 10-10-2008 01:25 PM
Gotcha, never paid enough attention to BBs to see that their intention was to provide that small positive psi. But the BB rep's response confirms that you lose the benefit of the EZ Lube design since you have to remove the grease fitting. EZ-Lube + Airtight is the way to go.
