1997 Chevrolet 3500
They use that engine in the Hummer H1 .
The only thing they dont like is fine sand dust ,other then that good engine if serviced well.
Friend of mine has one with over 300 K miles ,no isue what soever.
But i also tow my boat with a gas engine 350 Suburban ,just cheaper to fill up.
I tow boat/trailor loaded (14,700lbs) without any problem. No, it is no power house, but dose the job farlly well. 90,000miles when purchased and 4yr later 110,000miles. I would say the brakes are the down fall. Don't plan on stopping real fast. Modified the air intake, (ram air system), fan clutch, 4" exhaust. I drive 20mile grade across the desert out of LV to Havasu and she stays about 44mph (110-115 degrees outside temp). It dose improve in power when temps are below 90 in the spring and fall. Definetaly can tell a differance in performace. Never had any motor problems or overheating problems. Auto tranny works fine.
I thought everyone on OSO towed with 450's and up?!
Mines a '97 with 162k (one owner til 140K). Like previously mentioned, it gets the job done well but not a real powerhouse. I've installed aftermarket heads (factory cracks between the seats and GM replacements are no better), new steering gear from box to tie rod ends trying to solve a "shimmy". Turns out when they put the alumimum wheels on they thought 3 threads were enough
damn close to losing the wheels in my opinion.
Truck also has:
Alcoa style wheels, polished
235/85/16 tires
3 yr old trans (auto)
Front brakes and bearing hub assembly (2k miles)
Glow plugs
Cap
Dual power and heated seats
Why am I listing all of this???? Because I'm selling it! Feel free to make offer, will be in the ads soon.
damn close to losing the wheels in my opinion. Truck also has:
235/85/16 tires
Glow plugs
Cap
I had a 98 3500 6.5. Like stated above, not a big powerhouse, but if it gets the job done and can get a deal on it, it may be worth it. Injection pumps where a problem. GM extended the warranty on them to 12years 120,000 miles. Otherwise the engine was pretty tough. THe trans is a good trans also, aside form the high first gear ratio. This also contributed to the truck being a bit on the weak side. Brakes where ok as long as you kept the rear adjusted properly.
cigrocket
16
02-19-2006 09:15 AM
