2WD towing????
Old 11-15-2008 | 08:46 PM
axapowell's Avatar
Where To
Originally Posted by tblrklakemo
Why would you even consider 2WD when 4WD is an option....your just eliminating potential uses for a truck....especially in NY. Better to have and not use than need and not have.
In my case the only thing I do with my truck is tow my boat. An occasional trip to Home Depot, but that's about it. So less to go wrong and less maintenance with a 2WD plus I think the ride is far superior to a 4WD.
Dave
axapowell is offline
Old 11-15-2008 | 09:26 PM
Dave
I'll tell you what hardens a dually's ride; airbags.
Hot Knots is offline
Old 11-15-2008 | 11:19 PM
Sydwayz's Avatar
Forum Regulator
4WD is PRICELESS when you are slipping down a ramp backwards with no help in sight.
I wouldn't think of towing without it.
Sydwayz is offline
Old 11-16-2008 | 12:40 AM
phughes69's Avatar
Get the 4WD and if you can get the dually also. I have a 2wd extended cab dually with a Detroit locker in the rear and use it to pull a 38' Scarab. The boat and trailer weigh about 14000. I never thought I would need 4wd either untill the rear tires just started hopping on the DRY asphalt pulling the boat out of the water on a gentle incline (Metro Beach for those that know the area.) I had to very gently ease the throttle to keep the rear tires from spinning and this was about 30' from the waters edge. That experience REALLY made me want 4wd.
phughes69 is offline
Old 11-16-2008 | 02:20 AM
ya, thats it!
Perlmudder is offline
Old 11-16-2008 | 07:43 AM
Default Towe Veichle
I have a 2001 F250 v-10 4W/D it will do anything that I would get into but it's rare that I use the 4 wheel drive I tow a 271 FORMULA and have towed a 353 a couple a times never a problem ! good luck on your pick of tow truck $$$$ on your side now days !
tony manzella is offline
Old 11-16-2008 | 07:44 AM
seafordguy's Avatar
I have an F350 Dually. I wouldn't buy a truck without 4wd or diesel.
I have never had to use my 4wd, but the ONE time that you need it the extra expense will be worth it; net out the fact that resale on the truck will be better and quicker, and trust me - it will pay for itself.
It doesn't take much to get you in trouble - wet aggregate ramps, slightly worn tires, small amount of slime, etc.....
seafordguy is offline
Old 11-16-2008 | 07:46 AM
I tow a 4500# boat and bought a 4x4 truck last year. I have used it couple times in the past year, like everyone said it depends on the ramp/boat. I sometimes sue a crappy ramp on busy weekends because you need a 4wd or a really small boat. One time I used it is was about 9pm on a Sunday night with nobody around and I was 3 hrs away from home. Really nice to flip the switch and drive up the snotty ramp. I always buy 4wd, even though with proper ramp selection you can get away w/o it.
happy hours is offline
Old 11-16-2008 | 08:02 AM
cbgenrl's Avatar
4wd.
Another situation I have had to use it... My steel 30ft triaxle has surge brakes at all 6 wheels. I cant back up the slightest of grades on any type of semi loose gravel drive unless I shift in to 4hi.
Pay too much to have a truck that can't go to work when you most need it too. Had one 2wd in my life, never again.
cbgenrl is offline
Old 11-16-2008 | 10:10 AM
Sure is NICE to hit the 4-low button on a steep ramp....
26sxl is offline
