My new 05 EX
Old 04-20-2009 | 12:47 PM
bigboat28's Avatar
Good looking truck.
bigboat28 is offline
Old 04-23-2009 | 08:50 AM
Originally Posted by tony stamis
almost finished my new 05 EX still have to do the 4 inch turbo back exhaust ,S&B intake , Gauges and maybe Airbags in the back. i took off the 5.5 inch fabtech lift kit and installed X code springs with one leaf shim from an icon leveling kit and blocks in the back with a modified spring Ranchero 9000 in the back and RSX' in the front 35's on 20x 10 rubbs just a little if you turn all the way. Love the truck.
Great looking Ex, were are you rubbing? Those look like some wide 35's, and I am guessing you are rubbing on the leaf springs.
Be careful on the airbags for the excursions, the ones that get called out usually are the in-board ones, and not as heavy duty as the outboard ones for the superduty's. I am pretty sure you can make the superduty ones work. I am currently trying this on our 02 Ex.
D2HP is offline
Old 04-23-2009 | 09:30 AM
Speaking off..... If anyone out there has an Ex set-up similarly to Tony's that they want to sell, give me a shout as I may be of interest. Thx.
BowenCT is offline
Old 04-26-2009 | 03:36 PM
the tires are 35x 13.50 the truck came with a 5.5 inch lift kit i took it off and installed x code springs the tires rub a little i will probably go one size smaller with the tires i am just waiting to get everything finished up . no issues with the motor no puking antifreeze but the truck only has 46K on it.
thanks tony
tony stamis is offline
