Superduty Dually question
Old 05-15-2009 | 06:53 AM
From: A tree somewhere in the woods in Clarcona Fl.
Originally Posted by jmeng
Did you have to lift it to fit the 35s?
I used 265/70R19.5 tires with a 2 1/2" leveling kit on the front with NO RUB whatsoever.. I went with the Brentz direct fit wheels (pricey but worth it) the American Force 19.5's are 19.5x6 and the Brentz are 19.5x6.75 and the air pressure on the commercial 19.5 tires is rated at 110 psi, on my F350 I ran 65 psi all the way around, any higher and the ride got noticably stiffer and 65 gave plenty of support towing the boat due to the stiffer/heavier tire construction of a commercial grade tire. Also check load ratings on the wheels, forged wheels are much stronger than the cheaper cast wheels.
Slick02 is offline
Old 05-15-2009 | 07:44 AM
Looks great. Exactly how I'd like to set up my next truck.
jmeng is offline
Old 05-18-2009 | 08:03 AM
Thanks, I appriciate it, I'll do my next dually the same way.
Slick02 is offline
Old 05-20-2009 | 12:01 AM
2112's Avatar
Maybe I should wait for the 2011 model year?
Maybe they are going to fix the upside down headlight stack.
Attached Thumbnails Superduty Dually question-6a00d83451b3c669e201156e5931d1970c-800wi.jpg
2112 is offline
Old 05-20-2009 | 10:31 AM
Don't worry, the engineers still have a couple of years to screw that design up for the sake of the bottom line.
Slick02 is offline
Old 07-09-2009 | 02:34 PM
Default Brand new never installed F350 dually adapters for sale. $550.00 obo.
Xx
Tebo51 is offline
Old 07-09-2009 | 02:35 PM
904.845.8280
Tebo51 is offline
