Originally Posted by liveaboard74
(Post 2913651)
Dang.. forgot most important thing . Firestone air bags. No matter what you get,,, get a set of those on the rear. There cheep and my whole unit rides like a MB. I can control the air from inside the cab. I run about 60lbs.
Originally Posted by Catmando
(Post 2913793)
I've got them and if it didn't cost so much to remove them I would. Ride is much worse than stock when unloaded.
(Post 2913793)
10-15 lbs. in mine unloaded. 75 lbs. when towing & loaded. With my old 2 dr. Tahoe and 2500 Avalanche, I used to run 25-30 lbs. in them when not towing, just to keep the rear-sway under better control. |
I've got 06 PSD and towing just over 11K. Hyd. over electric brakes, it tows fine, a dually would do better. The air bags are a must. I can tell that I'm to the outer limits of what should be towed with the truck.
| All times are GMT -5. The time now is 06:23 PM. |
