Let's see your Ford or GM do this >
Old 09-06-2009, 08:34 PM
Originally Posted by 2112
And a non stop Cummins commercial.
Funny...my boat had a 540ci Ford motor. The only problem I ever had with it was the 1050 Dominator.
Go to posts 56-57;
http://www.yachtforums.com/forums/te...erunner-4.html
There's no doubt the Cummins is the best light-medium duty diesel engine out there. We'll see about the new 6.7 Ford, it sounds promising but it will still be a V8.
Catmando is offline
Old 09-06-2009, 09:42 PM
2112's Avatar
Go to posts 56-57;
Maybe you're not so bad after all.
Boat looks like a precursor to the Eliminator 234 Edge.
TRS drive?
2112 is offline
Old 09-06-2009, 10:04 PM
That semi was barely stuck. If that group of guys got behind it and pushed they more than likely could have got it out. Here is my point. If it was pulling a huge amount of weight the crappy 8-10K pound factory hitch would have snapped off. If the factory hitch did not hit the ground first, the junk Dodge tranny would have... Jeff
jwurl is offline
Old 09-06-2009, 10:30 PM
Forum Regulator
Sydwayz's Avatar
Received 1,195 Likes on 519 Posts
Cat...
Here's a 1/2 ton Avalanche (w/ 5.3L gas V8) pulling a semi out of pretty nasty snow. It's all about knowing what you are doing and traction.
http://www.youtube.com/watch?v=N4npjBkWr0I
Sydwayz is offline
Old 09-06-2009, 11:50 PM
TRS drive?
1) I'm still a Liberal, that's not going to change...
2) This hullform has been around for a long time. There was a 3 point boat called Spirit of America that crashed during a run for the world water speed record in 1955 I believe. Killed the driver. No one has used a 3 point hull for that record since then.
That hull was very unforgiving on reentry as you can guess from the transom pic. The Bladerunners are much better I'm sure.
3) Bravo1 drive.
Catmando is offline
Old 09-07-2009, 07:42 AM
Charter Member #232
Audiofn's Avatar
Originally Posted by Sydwayz
Cat...
It can't be Brian, that must be a photo shop job I tell you. It is all about gearing. I put mine in 4wd low and if you have the weight in your truck you are going to pull out the load if your drive shafts don't break. That is why you get on the gas very slowly.
Put your best foot forward!
Audiofn is offline
Old 09-07-2009, 08:47 AM
Well that's exactly what the Dodge driver did and he probly had the manual tranny. But as crappy as the Dodge automatics are, they can be rebuilt to handle lots of hp/tq.
Did you dig your boat out and run it this year?
Catmando is offline
Old 09-07-2009, 09:27 AM
Jassman's Avatar
Cat ... what you think buddy ... http://www.dodge.com/en/2010/ram_heavy_duty/
nice looking, all new sheet metal, new interior, just praying they updated the tranny... also waiting for the new 6.7 Ford to arrive before I make my decision. The 08 Duramax and Powerstroke will stay for another year.
Jassman is offline
Old 09-07-2009, 11:32 PM
I think the new truck is awesome!! You know you want one...
It's either the 6 speed Getrag(G56) transmission or the 6 speed Orion 68RFE. My truck has the G56 so I can't comment on the Orion. I've been on www.cumminsforum.com and can't find any threads about 68RFE problems. In fact most of the guys are saying get the auto even if you're towing heavy.
Catmando is offline
Old 09-08-2009, 12:26 AM
2112's Avatar
3) Bravo1 drive.
4 Point solid mounts? Drag boat style?
Did you work with Drew on the 540 ci combo?
2112 is offline
