Jacking up torsion axles
Old 10-15-2009 | 05:33 AM
I lift all three wheels off the ground with a large floor jack lifting against the bottom of the main beam of the trailer immediately behind the back axle.
BGIII is offline
Old 10-15-2009 | 02:51 PM
c_deezy's Avatar
Did my pictures in post #3 not show up???
c_deezy is offline
Old 10-16-2009 | 07:17 PM
sleek1's Avatar
Negative, I thought you were goofing on me. lol
sleek1 is offline
Old 10-17-2009 | 12:58 AM
c_deezy's Avatar
That's wierd. I put a bottle jack directly in front of the front axle and a bottle jack directly behind the rear axle. Jack the front up a bit, jack the reat up a bit, and repeat until all wheels on one side are off the ground and able to be pulled off the hubs. Then put a couple of 6 ton jack stands directly under the axles and slowly drop the weight off the bottle jacks.
I can send you a pic if the one really didn't show up. It worked out great, I was able to do the entire side.
c_deezy is offline
Old 10-19-2009 | 10:48 AM
Sea-Dated's Avatar
I can see the pic fine.
See if this shows up for everyone.....
I will try posting the pic for you instead of linking the pic.
Sea-Dated is offline
Old 10-21-2009 | 07:43 PM
sleek1's Avatar
C Deezy I got the pics (Sea Dated thanks for helping out). I will give your method a try.
sleek1 is offline
Old 10-21-2009 | 08:12 PM
c_deezy's Avatar
Cool. I don't take it up that high, just enough to get the wheels out from under it. I kept a little tension on the bottle jacks to help even the load after I dropped it on the jack stands.
Its funny to see it sitting there without any wheels on it, I had to order the bearings so it sat like that for a couple of weeks
c_deezy is offline
