-   Trucks, Trailers and Transportation (https://www.offshoreonly.com/forums/trucks-trailers-transportation-159/)
-   -   Thoughts of the 2004 Chevy duramax dually? (https://www.offshoreonly.com/forums/trucks-trailers-transportation/229877-thoughts-2004-chevy-duramax-dually.html)
joew. 05-06-2010 12:25 PM
Thoughts of the 2004 Chevy duramax dually? Any known issues?
The Get Away 05-06-2010 10:05 PM
Injectors
SDFever 05-06-2010 10:35 PM
Injectors and the cost associated with replacing them and you can't buy them new. You pay new price for factory refurbs.
If you can find a good tech at the dealer that will help you get a warranty set shortly before the engine falls out of warranty would be very helpful and cost saving.
Stay on top of that fuel filter and find a lower micron then the factory one. Stuff gets by it and it causes problems. And that water sensor at the bottom sux. It does not work worth a hoot based on my experience with some water in the fuel.
I could not believe what got past my filters in the past. Other than the shift patterns, the injectors are the only real issue I have with the truck. I've put 145k on mine since bought new in 04.
Catmando 05-06-2010 11:59 PM
You can buy injector nozzles from aftermarket outfits like Dynomite Diesel and others. They come in hp ratings so you can get 40 to maybe 150hp nozzles. As for fuel filters I use Wix in my Dodge. To separate water from the fuel the Airdog 150 fuel pump and bypass oil filter will get that job done. They're expensive but well worth the money.
Are you looking to buy the truck or do you already own it?
joew. 05-07-2010 07:58 AM
I have a lead on a very clean truck with low miles. From everything I read the injectors are the issue. This is the case with all diesels. The duramax appears to have the least amount of problems over the big three. Maybe I am wrong.
What does a set ov injectors and installation cost? Can I do it myself if I am fairly handy?
AngerMgmt 05-07-2010 08:46 AM
IIRC, GM extended the warranty for injector issues to 200K, with no time limit. Also, ACDelco just came out with a new fuel filter (TP3012) p/n 12633243, for all Duramax's 01-09.
200% increase in service life and greatly improves removal of emulsified water (the major contributor to fuel system issues)
My mechanic brought me one, but haven't changed it yet. $39.18..........
Jupiter Sunsation 05-07-2010 08:51 AM
On my 03 GMC just replaced all 8 under warranty at 145K miles. They have extended coverage on the earlier Duramax motors to 200K miles/7 years for injectors. I had not had a single issue until the injectors starting leaking. Motor has 6500+ hours on it and other than fluid changes/filters that has been it! The injectors are expensive (few hundred each X 8). GM covered the job and changed the oil as part of the recall/warranty. It has been 6months/12K miles since it was done with no issues.
Quinlan 05-07-2010 09:28 AM
Are those still used in my 07 classic?
Jupiter Sunsation 05-07-2010 09:36 AM
No.......the early Duramax's had defective injectors. The problem was corrected by 2004ish. Your classic has injectors but not the ones that were failing prematurely.
Busta 05-07-2010 10:46 AM
Joe - if the deal is right, I would pull the trigger. As others have said, the injectors are under warranty. You can't go wrong with a Duramax. I've got about 78k on my 05 and have only had one problem with the #7 injector plug (not the actual injector) which can be remedied with an ice pick! Other than that, no problems.
