Trailer maintenence
Old 08-24-2010 | 03:51 AM
I re-pack bearings each fall
Brakes replaced as needed as well as tires.
I do rotate tires when I do the bearings
Check tire pressure and give a couple squirts of fresh gease before each use.
When ever the boat is off the trailer I check the boards and bolts at least once in the spring and once in the fall.
If I am parking it for a long period I always park on a couple 2x12's as well as put on tire covers (even when its inside the barn).
After my last brake job I noticed a lot of rust from it sitting after launching so now I tow it 10miles or so to create some heat to dry everything out rather than launch and then let it sit for a couple weeks.
I also go through it anytime I let someone else borrow it (at loto many people don't have trailers so if you have a 38' trailer set up for a straight bottom V you find a lot of friends wanting to borrow it).
Lastly, I don't tow that much (spring, fall, mid summer drive service, and any repairs that pop up so less than 1500miles a year) because I normally leave boat on its lift so once a month or so I will take the empty trailer for a spin around my neighborhood just to get the tires rolling a bit.
I am a bit paranoid and I probably go overboard but I would rather check everything out often than be stuck fixing stuff on the side of the interstate with my family sitting in truck.
baywatch is offline
Old 08-24-2010 | 05:29 AM
I have a steel trailer and I dip in brackish. I had never delt with salt water before and I had alot of people tell me not to worry about it, that I was far enough up the bay that is was basically fresh water. Well, my new hubs lasted less than a season before the first one went, tire floated away while I was launching. When I was pulling the hubs I noticed that everything was completely rusted within the drums. I have a tandem trailer and when I was trying to get the boat off the ramp, the other axle gave way. It was rusted bad, from prior owners neglect in Florida. So $1500 custom made axles later and a $25 axle flush kit later, all is good. FYI, I had bearing buddies and plenty of grease.
Run_em_hard is offline
Old 08-24-2010 | 11:05 AM
augie58's Avatar
Has anyone done anything to treat the steel frame work? (thinking about the inside of the steel tubes)
augie58 is offline
Old 08-24-2010 | 12:05 PM
Airpacker's Avatar
Flush the brake fluid at least every second season. Prevents alot of master cylinder and wheel cylinder failures. Brake fluid absorbs moisture from the atmosphere and the water molocules travel through the fluid like electrons through a wire. Most f'd up trailer brakes are due to never having the fluid changed.
Clean, inspect and repack bearings every year. Replace as necessary and use NEW seals in the hubs every time. Physically inspect brakes at that time. Service as necessary.
Best time to grease then via fitting or bearing buddy is right after loading the boat. When you arrive at the ramp, the bearings are warm ( should not be hot to the touch ) and if you tend to splash right away, the cooling effect will draw water right into the hub past the seals. Really bad for the bearings if its salt water.
By greasing the hubs before trailering home, you can displace any water that may have been drawn in.
Ideally, wait a half hour after arriving to splash the trailer.
Tires, check pressure each time you leave home and before heading back. Check one and just rap the rest with a billy and listen for any differences. Practice at listening to the "poooong" sound and you can skip using a gauge all together.
Suspension pivot points. Use a heavy spray grease at all pivot and spring mounting points once a month if you trailer alot. Saves wearing away mounting bolts. Check axle to spring pad u bolts for tightness at least once a season.
Winch. Inspect cable or strap often. I have seen a few snap when pulling the boat out and it can be very violent and even dangerous to you or your boat. Grease the winch mechanism once a season as well.
Put a wrench on every nut and bolt at least once a season.
Inspect and lube with wd 40 or similiar the coupler mechanism once a month.
Inspect bunks and mounts quickly everytime before loading the boat. A loose or broken bunk can really mess up you boat.
Inspect the bunk carpet for rips or tears before loading the boat every time. Carpet is cheap, gel coat not so much.
I average around 4000 miles of trailering a year and this basic routine has saved me from any unfortunate incidents so far.
Airpacker is offline
Old 08-24-2010 | 01:48 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
I don't remember the temps offhand, but I just look for uniformity when towing. Anything that is out of the norm from the rest is in trouble, and that goes for tires, hubs, and brakes.
When towing in the daytime, the side to the sun will always have tires that are about 10 degrees warmer.
I also use it to test the tires on the truck at every stop, and also to validate engine, exhaust, and transmission temperatures. I've even been known to hang it out the window when driving in winter to test the road for freezing temps. Priceless tool & great for engine troubleshooting in the boat as well.
Sydwayz is offline
Old 08-24-2010 | 02:11 PM
My hub temps run in the 120-140* range when towing on the interstate. I check temps with an infrared heat gun at every fuel stop.
Griff is offline
Old 08-24-2010 | 04:28 PM
ChristianGott's Avatar
AP..good clear advice.
Griff..thanks, being curious i always wondered what temps they ran at..
i think i want an infrared heat gun for my birthday..
ChristianGott is offline
Old 08-24-2010 | 05:53 PM
I use the IR pyro on my tripple axle trailer and the hubs are 120* in the summer with a 10* varience between the 6. I run my bearings for two years, 1st year brand new, 2nd year repack, 3rd year new and so on.... I have the Kodak 225 disc brakes on my truck so I don't go through pads at all really.
I like the advise about flushing out the fluid!
This year (winter) I am planning on rebuilding my trailer running gear, new bearings, springs, pivot points, etc.. E-trailer.com will be happy with me.
Racerngr1 is offline
Old 08-24-2010 | 08:55 PM
thanks for the info!!!
1MOSES1 is offline
Old 08-25-2010 | 05:32 AM
neva satisfied's Avatar
I have a steel trailer that was dunked in the salt water 2 or 3 times by the previous owner. Is there something that can be done to the inside of the beams to help reduce the corrosion process? I have already flushed it a few times with Dawn dish soap and Salt Away. Or should I just bend over and hang on to my ankles.
neva satisfied is offline
