F350 Vibration
Old 11-11-2010 | 08:55 AM
seafordguy's Avatar
Originally Posted by Sydwayz
I had bearings, hubs, and ball joints done on mine around 100K miles.
If this is what you determine is wrong, let me know. My buddy in FL saved me over 50% on the bearings which were the most expensive parts.
Hey Brian - I think the Needle Bearings are only about 15 bucks a piece......
I think the Hubs are quite a bit more...
seafordguy is offline
Old 11-11-2010 | 10:44 AM
yeah, if you are 2wd the bearings are cheap. unless really loose i would not assume intermittent vibrations. are you feeling it in the wheel or in the seat. if its comming and going and you felt it in the seat i would take a look at the carrier bearing.
Fixxxer22 is offline
Old 11-11-2010 | 10:48 AM
if you are 4wd the front bearings are not servicable. they must be replaced as a unit. and they are anywhere from $300 to $150 for a assy. obvious that the 300 one is a factory. i would put it up on jackstands and run it in 4wd. set the cruise around your speed that you are hearing the noise and use a mechanic's stethascope and pinpoint the noise. no need to replace what's not broken. also offset wheels and big offroad tires are hard on these bearing sets. there are conversion kits to make them like the old spindle and needle bearing. i would reccomend that if you have aftermarket wheels and tires.
Old 11-11-2010 | 01:59 PM
seafordguy's Avatar
I was going to pull it apart and basically follow this write up:
http://www.guzzle7pt3.com/nblube.php
Old 11-11-2010 | 08:40 PM
I just did my f250 for the same reason... It is an 05 250.....parts were outrageous. I beleive it was $1800 something and only like 300 labor, but it drives and turns much better. They redid my whole front end assembly at 138k
FuelinAround is offline
Old 11-12-2010 | 01:31 AM
Sounds like wheel hub bearings to me. Mine acted similar on my Chevy 2500hd. You could feel the vibration more on smoother roads.
Just jack up the front end up and see if the wheel has any vertical movement. It almost feels like the entire wheel is loose.
BTW, mine were about $600 per side to fix at the dealer.
Griff is offline
