-   Trucks, Trailers and Transportation (https://www.offshoreonly.com/forums/trucks-trailers-transportation-159/)
-   -   When is it time(weight) to go with a dually? (https://www.offshoreonly.com/forums/trucks-trailers-transportation/244141-when-time-weight-go-dually.html)
weldcrane 12-17-2010 07:08 PM
it's allways better to over build than under build
GLH 12-17-2010 07:17 PM
Good point... We're still trying to figure out if we need a dually...
http://www.limestonedev.com/mti/2009..._4Internet.JPG
290enticer 12-17-2010 09:49 PM
I have surge brakes on my 29' powerquest. what is this eoh??
Outkast Rafe 12-17-2010 10:51 PM
electric over hydraulic
Catmando 12-17-2010 11:27 PM
I don't think you need a dually but 4wd wouldn't hurt...
GLH 12-18-2010 07:56 AM
It would hurt my azz.... These truck in 4x4 ride a lot rougher.
offshorexcursion 12-18-2010 10:23 AM
I own both and feel the single rear wheel tows as good as a dually. If you have a lot of weight over the rear axle (5000lbs+) you might like the dually better. That would require a load in the bed or a gooseneck/fifth wheel hitch. A tag/bumper pull style hitch does not have enough tongue weight (even a 46 black thunder does not have enough) to require a dually or even notice a difference in my opinion. I also hate dually's in the snow! Air bags will help sway along with properly inflated HD tires. I think the person behind the wheel makes all the difference! Does not matter how "overbuilt" your truck is, if you can't drive or don't have enough expierence!
Catmando 12-18-2010 10:57 AM
Have you driven a 4x4 with the Kelderman air ride?
Catmando 12-18-2010 11:29 AM
Whether you like a dually or not, the most important, and most overlooked, aspect of towing is staying within the rated limits of your truck for insurance purposes. Sydwayz has emphasized this point over and over again and it cannot be stressed enough. There can be serious consequences for overloading your tow vehicle.
weldcrane 12-18-2010 06:22 PM
1 Attachment(s)
i like my 4 wheel drive
