surge vs. e.o.h. brakes??
Old 06-03-2011 | 08:06 PM
  #41
I upgraded to the brake right 1500psi unit last summer with stock drums. It was a huge improvement but told myself I also wanted to upgrade to disc. I just ordered a complete disc brake conversion kit and all new lines. Plan to do it in the next 2 weeks.
Can't wait!
502ss is offline
Old 06-03-2011 | 09:07 PM
  #42
Rookie's Avatar
Originally Posted by RT930turbo
EOH is hands down the best system out there. However, I have had great luck with standard electric brakes. I have used them in a fresh water marine environment for a long time with no issues. The braking action is superb, and the cost to convert is about 25% of a EOH setup.
Can you elaborate a little? Is this what you are talking about?
http://www.northerntool.com/shop/too...ven=Aggregates
Rookie is offline
Old 06-08-2011 | 02:21 PM
  #43
are you going to put brakes on a golf cart ? those are 7 inch . if you have a 3500 #axle you need 10 inch brakes with 4 hole backing plate , 5200# axle is 12 inch brakes with 5 hole baking plates.
tim brown is offline
Old 06-09-2011 | 12:01 AM
  #44
Rookie's Avatar
LOL
No that was just an example. I just ordered 4 loaded 10" 3500lb electric drum sets, 2 backing plates for another axle and a 4 brake controller.
Rookie is offline
Old 06-09-2011 | 09:32 AM
  #45
Hey Rookie,
Yes, those are straight electrics, albeit WAY too small!
Just measure your drums, and order the assembleys. It's that simple. check out www.etrailer.com I have had good luck wuith them in the past.
RT930turbo is offline
Old 06-09-2011 | 09:33 AM
  #46
oops... look like you already ordered. Sorry I missed your question. You will love the brakes...
