-   Trucks, Trailers and Transportation (https://www.offshoreonly.com/forums/trucks-trailers-transportation-159/)
-   -   Lithium bearing grease? (https://www.offshoreonly.com/forums/trucks-trailers-transportation/247493-lithium-bearing-grease.html)
paulb32 02-12-2011 05:37 PM
Have a new trailer and the mftr insists on lithium based bearing grease. What bearign grease to you use?
I have the Safe-T-Lube hubs where the spindle is drilled and when pump grease in center, it pushes from back thru to the front.
I've found Mobil XHP222 that I might switch to. Any other good stuff?
offshoredrillin 02-12-2011 05:48 PM
from reading on here, I have the same style hubs, i just redid all 6 and went with the amsoil blue synthetic marine. i now have pressurized hubs so hopefully it will last longer too with no water intrusion.
RunninHotRacing163.1 02-12-2011 05:55 PM
+1 amsoil blue :ernaehrung004:
07DominatorSS 02-12-2011 06:01 PM
And even better than that, AMSOIL Series 2000 Racing Grease!!!:drink:
RunninHotRacing163.1 02-13-2011 09:08 AM
we'll have to give her a try :drink:
pullmytrigger 02-13-2011 04:43 PM
I would do what the manu says.....
paulb32 02-13-2011 05:26 PM
Thanks for the hits so far. I agree Amsoil blue seems to be the one, not hard to find either.
What about Lucas #2 Red & tacky? says llithium based and for marine use.
RunninHotRacing163.1 02-13-2011 05:30 PM
who's manu ????:party-smiley-004:
07DominatorSS 02-13-2011 05:42 PM
Personally. I wouldn't use anything Lucas produces, period. Part of it has to do with the following...
http://www.amsoil.com/lit/g2457.pdf
Both, they and Royal Purple, produce a product that doesn't even meet spec! Now who knows what all the rest of their products are like?!:eek:
SkiDoc 02-13-2011 07:31 PM
I've used the Lucas red and tacky for the last 5 or so years with good observations. Doesn't seem to break down. There may be a better one. I'm not pushing it but it has worked well for me.
