1999 Chevy Heat/AC Control Problems >
Old 02-20-2011 | 01:28 PM
Default 1999 Chevy Heat/AC Control Problems
I'm having intermittent issues with the heat and A/C controller in my 1999 Silverado:
  • Lights for recirculating and fresh air are both out (one or the other should be on)
  • A/C light stays on and I can't turn it off
  • Rear defrost button doesn't do anything
  • Defrost/dash/floor selector doesn't do anything
  • Temp selector doesn't do anything, all I get is cold air
  • The fan speed control DOES work though
Sometimes it works normal, sometimes not. Any ideas?? It's still winter here and I need my heat and defrost!!
MacGyver is offline
Old 02-20-2011 | 01:41 PM
Default Fixx
First if you have access at a scanner check for body control codes,,(BCM) if no codes then check for a blown fuse?? ma be cig lighter?? of a constant feed to the control switch...if you have a good ground and all the power leads have power suspect the whole control unit...they are between 90 and 150 bux for a new one and are common to fail..
FIXX is offline
Old 02-20-2011 | 01:47 PM
Not a blown fuse because it's an intermittant problem. I have a scanner, but I'm not sure it reads body codes. I'll check.......after the race is over
MacGyver is offline
Old 02-20-2011 | 05:39 PM
Just checked, no codes.
MacGyver is offline
Old 02-21-2011 | 11:21 AM
You better "MacGyver" something up......
pullmytrigger is offline
Old 02-21-2011 | 06:16 PM
LOL! If I can't find the real problem, I have the duct tape, Swiss army knife and a paperclip ready
MacGyver is offline
