Triple Axle Tire Wear
Is there a 'standard' tire wear pattern I should see on my triple axle trailer?
I'm asking because my front left tire was bald. right rear and right front tires are tied for the next wearing the next fastest but not bald. The others all seem about the same. I have disc brakes on the front two axles. I put the spare on the front axle. lubed everything up. and raised the hitch a couple inches (thinking there is too much load on the front) Dragged the empty trailer approx. 70 miles to where my boat is. All tires and hubs were good. Loaded the boat up, drove the 70 miles home. Center hub is smoking hot. no signs of other issues, tire wear, or brake problems. I'll swap the center hub but anything else I should look at? Tire rotation? |
1. Could brake be dragging that wheel?
2. Check alignment of axles, if that axle is an inch or two too far forward/back it would cause the tire to be dog legged out. 3. Was tire wear even or inside/outside worn? |
Originally Posted by Jupiter Sunsation
(Post 3377570)
2. Check alignment of axles, if that axle is an inch or two too far forward/back it would cause the tire to be dog legged out. 3. Was tire wear even or inside/outside worn? 2) haven't checked, but the trailer is less than 2 years old... 3) evenly worn right in the middle. I'll add that when I used the trailer all the time (boat is in rack storage now) my trip to the ramp was about an hour of twisty roads and turns. not sure if that matters. I was thinking if too much weight was on the front axle and I'm turning a lot, certain tires would just wear more? |
Worn right in the middle was probably over inflated, or a broken belt causing it to bulge out in the middle. I would be worried if it were on wither edge. just check the inflation, and do a visual on the treads often.
Originally Posted by rchevelle71
(Post 3377646)
I did the Jax. Poker Run a few years ago, 5 of 6 tires broke belts on that run, came home the last 20 miles on 4 tires! :eek: |
Fixx
Vette, check the tire dates,,they could have gave you old chitty tires..are they bias or radials?? i dont like radial tires on boat trailers,i like to feel what im pulling and bias seem to last longer for me..
(Post 3377678)
Broken belt usually blows tire long before it wears out!
The front axles take a lot of abuse when parking the boat in a tight space. Are all the tires straight up and down.
I know I bent an axle once because I turned the trailer too hard backing up and it dragged the tire sideways bending the axle. |
Originally Posted by mrfixxall
(Post 3377708)
I do park have to extreme turn to get it in/out of my driveway. Talking near jackknife to get it in. I'm anal about air pressure. all the tires are inflated to spec. |
Originally Posted by VetteLT193
(Post 3380035)
| All times are GMT -5. The time now is 03:21 PM. |
