Originally Posted by dewayne6243
(Post 3421146)
Ron and Pam Manning. Same as always.
boatme says when he owned it? My guess is your trailer is under a Sunsation We did alot of trailers back in the day for Joe when I owned Manning The purple was a Kustom color to match the boat purple paint. What is under the purple paint it is a light grey primer then the color is sprayed then the clear coat is added to the process (was very expensive to paint ) Later on we found a paint that was close to the same color with out the 3 step process (Only two step) You can touch it up with original paint just takes a bit of talent and a bit of build up They said they do not keep records of paint codes/ build sheets of trailers they build.My Buddy is haveing trouble with his Manning trailer. |
Ttt
| All times are GMT -5. The time now is 08:27 AM. |
