Ford Excursion V-10 Exhaust Manifold Leak?
When I drive I hear a loud exhaust noise comming from the engine, its louder as I get up to speed, then quiets down as the rpms go down. Its only really there under a heavy acceleration. Anybody have this isssue with there v-10 excursion yet, is a major deal to fix?
Exhaust manifold leaks are fairly common on the Ford modular motors. You've got an aluminum head with a cast iron manifold and steel studs - which corrode and fail. We see lots of this up here in the road salt capital of the world.
Basically, you have to heat and shock cool the broken studs carefully to tease them out. And you might as well replace all of them while you're in there. It's best done though a wheel well. Not the worst job I've ever done, but somewhat of a pain.
I wasn't aware of another material being offered. We've always just put the Ford studs back in.
I have the same deal but on a F-350 but I would NOT put the stock manifolds back on way too much $$$$ I went on line and ordered a exhaust system from Summit Racing headers to the tail pipes for hundreds less than 1 Ford manifold!! Not sure what kind of miles you have on the truck but I was around 90K when I did mine and of the 20 studs 18 of them broke!!!! much cheaper and even kind of sounds cool now....LOL
