Towing boat, no motors or drives? >
Old 10-20-2011, 03:17 PM
Default Towing boat, no motors or drives?
Has anyone towed a 38-42' boat without motors or drives for a long distance, 10+ hours? If so, what should I think about before attempting?
I'm thinking it could be as easy as hooking up and taking off, or it could increase tongue weight to a dangerous level. Should I slide the boat back on the trailer for better balance? It is a triple axle Myco trailer. Thanks for any advice you can send my way!
TCBoss302 is offline
Old 10-20-2011, 04:03 PM
I don't think you will have any issues as long as the tow rig is up to the task. There will be a slight increase in tongue weight, but that is better than a reduction. I would just hook up and roll.
RT930turbo is offline
Old 10-20-2011, 04:14 PM
Agreed. I've not had a problem.
POWERPLAY J is offline
Old 10-20-2011, 04:28 PM
I have done it many times with my F350 Dually. No issues at all. As long as your truck is rated for the weight of a boat that size just hook up and go. Good luck and have a safe trip.
Osageparty is offline
Old 10-20-2011, 06:47 PM
Registered User
Ditto, pulled a 38 ZRC about 450 miles, no engines or drives, made no difference in the way it towed. The 3 axle trailer will help keep the weight distributed nicely.
Bathtub is offline
Old 10-20-2011, 07:27 PM
21 and 42 footers
t500hps's Avatar
Pulled a 38 with drives but no engines 30 miles.......BUT, both engines were in the back of the truck!!!!! It was certainly different but made it down the highway fine (in a dually).
t500hps is offline
Old 10-20-2011, 07:40 PM
Forum Regulator
Sydwayz's Avatar
Received 1,238 Likes on 532 Posts
You probably ought to stick 1600 lbs of topspoil in the bilge in sandbags.
Then you can tell the wife you brought her a new garden as well.
Everybody's happy.
Sydwayz is offline
Old 10-20-2011, 08:17 PM
Home depot sandbags, return them at the other end!
fossil fuel is offline
Old 10-21-2011, 05:40 AM
Quinlan's Avatar
dWe pulled a 42 Fountain from Miami to OK, No motors but it did have 6s hanging on back. Did not seem to taw any worse.
Well except for that Blow Out at 4 AM in the middle of NOwhere Ark.
Have 2 spares!!
Quinlan is offline
Old 10-21-2011, 07:39 AM
Thanks guys, sounds like it will be just fine, I appreciate the input!
