GM Techs need some help please
Old 03-23-2012 | 07:26 AM
Rookie's Avatar
Originally Posted by boatnt
I would not think its a Throttle position sensor either,,trans gets input from the TPS,if that was the problem you would also notice hard/firm trans shifts..
Thanks everyone. So it still runs fine in the morning when it is cool out (15miles to work) to work. But after sitting 9 hours while at work it acts up within the first 1/2 mile after sitting in the 85*F weather. Might just be a coincidence.
Boatnt... It does have some different shifting points when it is acting up. It seems to shift out of the gears faster, I will be in overdrive by 35mph. Some times it will not shift into 3rd until 3000 kinda erratic.
Originally Posted by 575cat
Converters plugged ????
Will have that checked out.
Thanks all for the suggestions
Rookie is offline
Old 03-23-2012 | 08:08 AM
mrv8outboard's Avatar
coolrunning racing
Check the coolant temp with you dongle to see if it is accurate. Put a fuel pressure tester on it to verify fuel pressure.
mrv8outboard is offline
Old 03-28-2012 | 07:53 PM
Rookie's Avatar
Quick update:
The last few days the truck has been running pretty good, slight hesitation above 60% throttle.
I disconnected the mass air, put in a known good mass air and TPS with no change.
This weekend I will hook up a fuel pressure gauge and do a back pressure test on the cats.
I hooked it up to my brothers Snap on Solus and it had no stored codes and all checked good.
As always, thanks
Rookie is offline
Old 04-11-2012 | 12:44 PM
Rookie's Avatar
Another update:
Fuel pressure checked out good.
There was a small measurable amount of back pressure on the passenger side cat.
I replaced the TPS.
Today I replaced the battery and now all hesitation has gone away. I can put it to the floor and it runs
great.
Thanks everyone for all the suggestions. I hope this was it.
Rookie is offline
Old 04-11-2012 | 03:26 PM
Rookie: Sometimes all it takes is a battery. These vehicles are sensitive to that and it seems strange that a battery will "function" but not allow a vehicle to run right.
Wannabe
wannabe is offline
