roller trailer - roller relocation question
Brian, my 272 is on its original Load Rite which is the first roller trailer I have ever had (out of 18). Your spacing is definatly off as compared to mine. As far as bunk to roller I would say it all depends on the ramps you use. You dont have to get the trailer as deep on launch or retrive so in that respect it is easier. You have to find just the right depth for both. For me to launch, the fenders just out of the water and I can unhook it and just tap reverse and it floats right off and load, the back rollers just underwater and I can drive it on just like a bunk. Just leave the motors in foreward idle and hook the bow eye. I know a bunk is better support for the boat but will use this until I find a good deal on an aluminum bunk in the future. Was very skeptical about the roller but its not as bad as I thought it would be. Hope this helps....Brad.
WITH CROSS WIND IT WOULD DRIFT AND MIS- ALIGN
WENT TO ROLLER AN ONCE YOU LOCK INTO THE FIRST SET TAP THE THROTTLE AND YOUR ON
I guess 75% of the trailers we see here are bunk style. I had a roller trailer out of Michigan and it was a hand full at the ramps...talk about tough to center. It was painted steel and was like an Alka Seltzer in a glass of water down here....I could watch it corroding in my driveway. Very heavy also.
