Ford Upfitter Switches
My 2011 F-250 is equipped with upfitter switches. I want to add some lights to help with night launching and backing up and lights in the bed. Has anyone added anything to the switches? Where are the wires that go to the switches? Any one got any recommendations on good back up lights? Thanks
Originally Posted by SkiDoc
(Post 3665719)
I did it on my snowmobile trailer through the trailer plug (not the 4 prong but the larger one. When I put it into revers the lights come on. It works real nice, I have 4 fog lights on there.
Thanks for the info.....
(Post 3665719)
1 Attachment(s)
(Post 3667527)
Its in the manual, and I thought the relays are under the hood.......
witch one do you use for the fast idle , and how do you hook it up ?
Regarding lights.....
www.rigidindustries.com There is no question that they are the top of the line... Many offroad shops sell them. We sell them as well if you need help getting them. There is a new one called a SRM that is just coming out that is smaller if you are not looking for huge light. We have been putting them on some boats, and we are going to put them on the shop trucks as well. |
Originally Posted by tim brown
(Post 3667686)
http://www.ford-trucks.com/forums/10...ml#post9494561 The variable potentiometer (pot) is the way I went. That way you can tune the idle rpms on demand. I drilled a small hole through the fuse panel cover and mounted it there. I used switch #3 because it's the lowest AMP rating, so to save the higher current circuits available for other future purposes. |
Originally Posted by CigDaze
(Post 3667616)
Nope. Under dash.
| All times are GMT -5. The time now is 10:26 AM. |
