-   Trucks, Trailers and Transportation (https://www.offshoreonly.com/forums/trucks-trailers-transportation-159/)
-   -   Military Hybrid Hummvee (https://www.offshoreonly.com/forums/trucks-trailers-transportation/276338-military-hybrid-hummvee.html)
Catmando 05-13-2012 01:44 AM
Even the Military is going green how you like that boyz! :lolhit:
http://www.gizmag.com/hybrid-humvee-...m_medium=email
Still think hybrids and green cars are meek and hipsterish? Plant your eyes on the US Army's Fuel Efficient ground vehicle Demonstrator Bravo. It's one of the burliest vehicles you've likely seen in years, and it's all hybrid underneath its rugged metal shell.
If you think you spend a lot of money on gas, imagine how much money the world's most powerful military – with its tanks, generators, military bases, Jeeps and on and on – must spend on gas every day. Since being the world military leader also empowers you to, say, go out and develop the most advanced hybrid vehicle technology the world has ever seen, it's not too surprising to see the Army putting some of its resources toward building a cleaner, cheaper wheel.
The FED Bravo builds on the original FED concept shown last fall (the FED Alpha, in true US military fashion), adding mobile power supply equipment – besides running partially on electric power, the FED Bravo can also feed power into a microgrid for use at small military outposts.
In addition to its new role as mobile power station, the FED Bravo uses a completely different powertrain from the Alpha. In place of the original Cummins four-cylinder engine, the Bravo features a more powerful 4.4-liter twin-turbo Ford V-8 worth 268 hp. It gets its green cred from a road-coupled parallel hybrid drive system with a front-mounted electric motor and rear-integrated hybrid system. An engine start-stop system adds further fuel savings.
The Army didn't get into what type of fuel economy we're talking (probably because the fuel economy of a 17,000-lb (7,711-kg) armored truck wouldn't be all that impressive to the average consumer anyway), but when it first showed the non-hybrid Alpha model, it said that it would burn up to 70 percent less fuel than a standard up-armored Humvee. The New York Times reports that the Bravo gets 8.2 mpg (28.L/100 km) city and 14.2 mpg (16.5 L/100 km) highway, about double the numbers for a regular Humvee.
Proving it isn't any compact hybrid sissy, the FED Bravo uses an armored cab atop a tubular space frame designed to increase rigidity-to-weight ratio, not to mention a V-shaped hull for blast protection.
The Army received Department of Defense funding for the project and worked with a group of 18 students from Detroit's College for Creative Studies. The concept was developed at the Army's Tank Automotive Research, Development and Engineering Center (TARDEC) in Warren, Michigan with industry partner World Technical Services, Inc. The Army showed the concept at the recent Society of Automotive Engineers World Congress, which took place late last month.
Sydwayz 05-13-2012 07:28 AM
No, they're not. :angry-smiley-038:
Jay Gadsby 05-13-2012 09:46 AM
Yeah, I dont see that getting field time anywhere in the near future. I will be retired before a replacement HMMWV enters my motorpool, almost willing to bet on that. Look how long it took just to add the armor onto a base HMMWV.
Steve 1 05-13-2012 12:12 PM
This word “Green “ should be changed to "Commie” , Same crippling effect on our society , We have plenty of fuel , ONLY thing missing is the WILL to get it .
Catmando 05-13-2012 03:12 PM
The name Steve Koss should be changed to "Clueless Knucklehead".
Catmando 05-13-2012 03:19 PM
How much time do you have left? If Obama fast tracks it you'll see them sooner than you think.
Rumsfeld kept putting it off is why. Even when it became clear to him the war would last longer than the three months he told us, he still wouldn't up-armor the vehicles. The scumbag didn't want to spend the money to protect the troops.
Steve 1 05-13-2012 03:23 PM
Something you have heard all your life ??
ChargeIt 05-13-2012 11:23 PM
From what I have read and seen, fuel efficiency is not necessary as a primary attribute.
Vehicles are going to get damaged and destroyed before the scales can tip in favor of fuel efficiency.
Not to mention, simplicity is key on a battle field. How fast and minimal tools are necessary to repair a vehicle.
Now if stealth (quieter) is mission desirable, consideration. If the dual function of transportation and power generation is found to be worth while vs the logistics of a generator and maybe other benifits then those can try to be quantfied.
"basic" troop transport seems to be an evolving animal. The Jeep was good for 40 years. HumVee, 25 now? Both were asked to do much more than their original design specs.
A new vehicle, ok. Pushing concepts is what nurtures advancement but WWII history with the German Tanks suggests making something too complicated and expensive can be crippling to the overall effort.
Catmando 05-15-2012 12:19 AM
Yes they are. They need to save money and fuel is a big percentage of their budget. They're looking at alternative ways to burn less fuel. Is that a crime in your eyes?
RivMan 05-15-2012 07:44 AM
The last number I heard was that fuel in the field costs the military about $300 a gallon. Fuel efficient vehicles are very much on their mind.
-Rob
