master cylinder
Old 06-02-2012 | 07:54 PM
Default master cylinder
I need a master cylinder for my 2005 Continental trailer with surge brakes, any ideas where to get one or can it be cross referenced to buy at the local parts store? Thanks.
Troy Ray is offline
Old 06-02-2012 | 09:11 PM
Default fixx
by the time you save yourself a hundred bucks and once you get in their their may be a bad shock,broken spring and bolts..for the 169.00 for a complete unit and just a matter of 2 bolts and the brake line i would just replace the whole thing..if you deside to order the whole thing make sure you order it for what style brakes you have,disc or drum..
this place has reasonable prices..http://www.etrailer.com/dept-pg-Acce...-pm-Titan.aspx
FIXX is offline
Old 06-02-2012 | 10:30 PM
thanks for the info.
Troy Ray is offline
