2012 Silverado leveling keys
Old 08-05-2012 | 05:44 PM
Default 2012 Silverado leveling keys
Does anyone have any experiences with leveling keys on a chevy or GMC truck with torsion bar suspension? Just want to hear some opions before I go out and buy them.
Donzi Andy is offline
Old 08-05-2012 | 11:30 PM
Default fixx
1500 i use the spacers,,they have front coil over shocks,,work great..
2500 have you tryed to tighten the bars first? i usually go 4 turns,gives you 2 ''..doesnt make the front end nose dive when you slam on the brakes as well..
FIXX is offline
Old 08-06-2012 | 03:09 AM
gmhdfan's Avatar
Chevy-Harley fan
Not sure about the new trucks but the older ones you can use a ford key.
Pete
gmhdfan is offline
Old 08-06-2012 | 06:18 AM
Depends how much "level" you want.
I have 305/55/20 tires on a 2012 HD3500 SRW 4x4 and tightening the torsion bars was enough. I bought the keys but didn't end up needing them. Let me know if you want a set still in the box
You will need either longer front shocks or shock spacers between the top of the shock and the shock mount, otherwise the shock tops out and makes the ride harsh. I used the spacers until Bilstein gets around to actually shipping their 2012 shocks.
Don't get sold on the upper control arms due to the balljoint angle sales pitch. And be sure to leave enough gap between the bottom of the upper control arm and the droop stop on the chassis just outboard of the inner bushing or you will hate the ride. I have about 3/8" at that point which gives a height to the bottom of the fender arch of 42-1/2" vertical above the wheel center on that size tire.
Don't forget the alignment afterwards obviously.
Hope that helps.
Rookie17 is offline
