-   Trucks, Trailers and Transportation (https://www.offshoreonly.com/forums/trucks-trailers-transportation-159/)
-   -   New Manning... (https://www.offshoreonly.com/forums/trucks-trailers-transportation/292814-new-manning.html)
Sydwayz 03-11-2013 02:20 PM
If it were me, I would take the wheels off of the front two axles and put them in the bed of the truck.
Looks good Mike!
FIXX 03-11-2013 06:05 PM
fixx
Originally Posted by Chart (Post 3883643)
Take most of the air out of the trailer tires for the empty pull south. That will help with the bouncing problem. I once pulled an empty tri-axle trailer 1500 miles, and it bounced like a basketball until I did the following:
Your tires are probably rated for 80psi and are rated for +- 3000 lbs at that PSI. Your empty trailer probably weighs 3000 lbs on the axles at most, or about 500 lbs per tire. You can likely get by with 20-25 psi and have plenty of air volume to carry the load, not get hot, not bounce your trailer and truck, not tear up things, and actually track better.
Be sure to air back up before loading the boat. Do the same with the rear tires on the truck.
^^^^ +1 but im a tire guy also,,run a minimum of 35 psi or your trailer will end up like a ford explorer..
ICDEDPPL 03-11-2013 06:11 PM
Just put your wife on your lap, and let the fun begin!
Chart 03-11-2013 06:59 PM
That brings up a good point, check your tires and hubs at each stop for unusual heat, a sign something is going wrong with the bearings, or too little psi in the tire. My rule: if you can hold your hand on the tire, and touch the hub, you are still good. (different tests, not at the same time).
I.D.C.E. 03-11-2013 07:47 PM
Amazing trailer, what brand axles do manning use?
hammer01 03-11-2013 08:51 PM
I'd also be sure to hit plenty of car washes as the shixxx salt roads will eat up everything it touches. Are you going to dip it or are they lifting it out for you? Looks great buddy.
sommerfliesby 03-11-2013 09:08 PM
I'll dip it. Once in, once out. That'll probably be the exent of salt water it'll see in its life with me.
laszlo01 03-11-2013 09:13 PM
Looks great Mike. Manning built mine almost just like that one but with drive guards to extend it. You will love it great guy to work with.
Expensive Date 03-11-2013 09:47 PM
Looks great, I love mine don't remember it bouncing coming back from Michigan but mine is only a tandem.
US1 Fountain 03-11-2013 10:21 PM
Originally Posted by Wildman1 (Post 3883532)
Can you ask them what vender supply the center caps for the wheels. They are 7000 lb axles because you got 8 lugs on them. I have been looking for that kind for over a year now with no luck. Search the Internet with no luck,even check Summit's racing site. They are 5 1/4 in diameter.
My Eagle has the same wheels and center caps. Inside of my wheels have casting; MFG by MS. No luck doing a search though.
The eagle website list 5.15" dia SS center caps in both open and closed ends.
No pics.
