Tie Down Actuator and solenoid problems >
Old 04-01-2013 | 09:12 AM
Sydwayz's Avatar
Forum Regulator
As much as you have gone though, and with the truck you have which includes a factory brake controller...
...yank all that surge brake crap off and go with EoH. You will be miles ahead, and have a 10x better braking system.
Sydwayz is offline
Old 04-01-2013 | 09:33 AM
c_deezy's Avatar
Are you sure you have the bleed-off tube lock-out solenoid?
You have to be sure you don't have the brake actuator compressed before shifting to reverse and activating the lock-out solenoid, or else you are going to be locking the brakes actuated. If the trailer has a 5-flat it should be the blue 5th wire running to the actuator, as you said it is.
Pictures of the set up would help for troubleshooting.
c_deezy is offline
Old 04-05-2013 | 07:28 AM
That is exactly what I think is happening. The trailer is pushing down hill towards the truck. When I put the truck in reverse at that time and attempt to back up, the trailer did move but I think the solenoid fried at that time! Once I get this repaired, I am just going to use the lockout pin hole in the actuator until I get on a more level surface and all should be fine. When on a flat surface, the actuator is not compressed and the brakes are free and backing up is fine. Again, I think this is the problem. Tie down manufacturing has "STILL" not returned my calls! Not impressed with them at all!!!
baja25sst is offline
