Tongue weight
Old 04-28-2013 | 10:52 PM
Thumbs up
Haha , speaking of off topic I was finally able to put to use the switches you turned me on to. I like em a lot hope they hold up
ICDEDPPL is offline
Old 04-29-2013 | 09:38 AM
check the capacity of hitch/vehicle.. too much will sway and too little could affect traction on launch and cause tongue to bounce on ball also...
I would say 600 - 1000lbs depending on hitch/truck.
nailit is offline
Old 04-29-2013 | 04:26 PM
Originally Posted by ICDEDPPL
Correction, I just took my buddies 91 dually out to see what would happen and no more sway.. none , ZERO. So in my case anyway it seems tow vehicle makes a big difference
I am now in the market for a dually.
Duallies can mask a lot of trailer not-set-up-right problems. Not arguing against a dually for a heavy 38' boat, it is the right truck, but your trailer is not set right whether you have a dually or not. So for your own sake, and those on the road with you, please keep dialing in your trailer.
Chart is offline
Old 04-29-2013 | 04:37 PM
Used to hear that boat trailers needed 5-10% tongue weight. Now you usually hear aim for 10%. I think somewhere between those is probably going to be fine.
Boat trailers are a little different from most other trailers, in that the axles are pretty far back, and the bulk of the weight is close to the axles. There is less tail-wagging-the-dog on a boat trailer than most other trailers because of that. Other trailers aren't going to endorse 5%, but that was followed by boat trailers for years without significant problems.
If you have a choice, try to get close to 10%.
Chart is offline
Old 04-29-2013 | 04:45 PM
Ok, this morning I called Manning and MyCo.
Manning said 5-10%
MyCo said 6-10%. He also said their sweet spot is 6-8 but never less than 6.
Hope this helps others like me that are trying to get set up properly.
Pwraddr is offline
Old 04-29-2013 | 06:38 PM
Very nice! I like it
502ss is offline
Old 04-30-2013 | 03:05 PM
Manning said 5-10%
Thank you for posting this, good info.
I tow a 9,500 pound travel trailer with the burb and I am set up at 10% tongue. it tows fantastic, so well you have to remember it is back there. On travel trailers I was told 10%, maybe a bit more is the goal.
Boats I am new to but had heard the same thing, below 10% down to 5%. 6 to 8% sounds great. I am redoing my trailer right now and have a full scale at work, so weighing and calculating it out is nice and easy.
Can't recommend running it across the scales enough and getting all the axle weights.
Brian
befu is offline
