Removing clear coat from chrome trailer rims >
Old 07-24-2013 | 10:56 AM
Default Removing clear coat from chrome trailer rims
Previous owner sprayed chrome trailer rims with clear coat and it's starting to peel and dull. Looks like s%it. Trying to figure out the best product to remove it as the rims look great underneath where it's peeling.
H2O DOG is offline
Old 07-24-2013 | 11:23 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Have you tried a pressure washer?
Sydwayz is offline
Old 07-24-2013 | 02:24 PM
No because it is really on there across 99% of the rims. Even where it is flaking, the edges are still well adhered.
H2O DOG is offline
Old 07-24-2013 | 02:28 PM
pressure washer might still work, specially if you start catching some edges. And to be honest no amount of pressure on a normal pressure washer is going to hurt them. Other than that, maybe somebody that knows something about paint could say, but I would try laquer thinner, not mineral spirts the tru laquer thinner, that strips off a lot of stuff. otherwise maybe try gas first and work your way up. But start using chemicals you better protect the rubber somehow.
soldier4402 is offline
Old 07-24-2013 | 03:20 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
You can usually replace a trailer rim for $100 bucks or so. They are somewhat expendable.
I just painted mine with www.dipyourcar.com stuff and am happy with the results.
Sydwayz is offline
Old 07-24-2013 | 07:35 PM
tcwcar's Avatar
Joe
I have stripped some with that spray on paint stripper, NAPA is were I got the stuff from.... worked great...
tcwcar is offline
Old 07-24-2013 | 07:56 PM
Plastic media blaster. We use it to remove epoxy paint from F18 hydraulic motors for the flap system. The base material is a simple aluminum forging and the stuff works by impacting the aluminum and squashing which acts like a wedge under the coating. It's gentle enough that we use a Sharpie pen to write a serial number on them for tracking through the facility, paint them with epoxy and when they come back in for overhaul and we blast them to remove the paint,the Sharpie markings will still be intact because the media doesn't damage the base material.
bonesmalon is offline
