I was running a regulator on oxygen, changed the nipple when I went to nitrogen.
Each tank change is 47 bux....
Originally Posted by s022mag
(Post 4007948)
He's running a regulator you have to with nitrogen tanks. Now I do know that nitrogen is a dry air that's why we use them at work, your compressor with have moisture unless you install a dryer of some sort like what people use on paint guns. Don't know if that could be a problem for you.
My switch actuator just $hit on me about after the 5th hit, the gasket is leaking, could be from age, or possible not rated that high. How much does it cost to fill your tank? |
Thanks for the input Sydwayz!
I have a Nathan 5K on my pickup and as far as I'm concerned that's the only thing to run. I have access to more. We run the them on all our semi's as well. Purdy pricey but well worth it.
No experience, but they just put one of their kits on sale for $200 and free shipping:
http://www.hornblasters.com/products...-air-horn-kits |
| All times are GMT -5. The time now is 01:00 AM. |
