Looking for basic Trailer tires. Any recommendations? >
Old 01-23-2014 | 01:42 PM
Knot 4 Me's Avatar
Originally Posted by jvthundercat
In a comparison, I would not take FREE Marathons if I could pay full retail for Maxxis. It is not worth the trouble to me with the "life" experiences that I have had.
Yes, they are that good. No heat build up, no scoffing. I have gone through a new set in less than 1000 miles just from turning with a triple before.
I almost went with Maxxis but I wanted new wheels and Treddit did not offer them as an option. I've ran Marathons on all 4 of my trailers for thousands of miles over a 16 year period and have had zero failures. Therefore, I was comfortable sticking with them. However, just as with Carlisle some folks have had horrible luck with Goodyear. I've heard nothing but good on Maxxis.
Knot 4 Me is offline
Old 01-23-2014 | 02:14 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Originally Posted by Knot 4 Me
Brian, my new ST225/75/15 Goodyear Marathons are D load rated.
Thank you.
I can only fit the 205s on my little boat's trailer.
Currently running 205/75/14s at 26.11" tall.
Going to jump up to 205/75/15s at 27.11" tall.
The 225/75/15 at 28.29" tall; and nearly and inch wider is not going to work.
The trailer was built in 1976 or so. Everything was smaller back then, myself included.
Sydwayz is offline
Old 01-23-2014 | 09:22 PM
I installed a set of Maxxis 225/75/15 E load and couldn't be happier.
underpsi68 is offline
Old 01-24-2014 | 12:30 PM
For some reason my trailer is 1981 and has "Turbine" style "Mags" that are 14x7/ I do not know if you can (scratch thay SHOULD) put a 215/75/14 on a 14x7 rim...Anyone. If I don't use these I will buy a premounted tire/wheel.
cyrus77 is offline
Old 01-24-2014 | 12:44 PM
Knot 4 Me's Avatar
You think the wheel is too wide?
Old 01-24-2014 | 01:17 PM
If is is a single axle trailer you can use an automotive tire with no issues. I would look to go 15" in a lower profile if it will meet your weight needs.
sbslinde is offline
