Chevy 1500 with Max Tow Package
The factory shift points in my suburban where awful. I modified all of them and now it tows like a dream and the trans doesn't get over 190 going 80 in the hills of michigan pulling 6000lbs.
Great thread I an in the same position 90% of my towing is within 3 miles including gas station, otherwise the ramp is a mile away, I to think I'm going after a max package truck, cannot justify a gas hogging 3/4 or a diesel,
I have a 2013 Silverado 6.2 litre 4x4 with the Max tow package and 3.73 gears. I went from a 2005 Duramax to this truck. The towing power is no where even close to the diesel. The truck is fun as a daily driver but the gas mileage is pretty bad. I average 13.5 with mixed highway and city driving. The best I have ever seen on a long highway trip was 16.7mpg. I just towed my 8k boat 250 highway miles and the truck averaged 9.5mpg. The engine has plenty of pulling power but the 1500 chassis is where the truck lacks. It Does not have the ability to pull a trailer with a decent tongue weight and load up the bed without the rear bumper dragging the ground. I could load up my 2500hd and the thing would barely sag. Its a nice truck but it is not a 2500 and not a diesel. Jeff Wurl
I have a 2011 Sierra 1500 with the max tow package, 6.2 with 6 speed and 3.73 rear end with the bigger brakes. I flat out love the truck, my daily drive in 30 miles each way mostly at 60 mph and I average 16.1 mpg. The truck has a ton of power and every now and then I pull a 8,000 lb skid loader. It does it fine, you know it is back there but it starts and stops it fine. I mostly tow a 5,000 lb boat and it does a great job.
As mentioned above the 1500's do sag but the key to this is the getting air bags for them. $300 bucks and you add some air when you tow, levels the truck out and still rides great. Firestone makes an airbag kit that does not even require drilling, bolts on in 30 min and is great.
Now believe me a 2500 duramax is in a different league towing but it also does not ride or drive as well as the 1500. For an all around truck to drive daily and tow occasionally the 1500 max tow is the way to go!
Yep my 03 Silverado SS I sold to by the 2500 hd sagged real bad, hence the upgrade to the 2500, but I only had the 2500 8 months and had enough of the rough ride and **** milage, the 1500 Denali does not sag with my VR1 on the back.
It appears the consensus is that the 1500 Max Tow is a great truck if used correctly. As soon as I get my wife to concede to me buying a new truck, I'm ordering a Max Tow. I know once I get it and the warranty is up, It will get a set of long tube headers, high performance brake pads, cold air intake, and a complete re-tune. I like the air bag idea as well, I'm up for any more good ideas as well, keep them coming. To those of you that have them, how is the torque converter engagement? I tried a smaller torque converter on my Suburban and the difference was very significant, especially getting a load moving from a light. the LS motors like to rev and the best thing you can do is let them get to their power band quicker.
Mine will have a awkward setup. CTS-V TVS 1.9 blower swap. Long tubes (ARH) 1 3/4 and bigger injectors and already for e-85. And the true 3" MBRP cat back setup from my old 2012 camaro SS + high flow cats. I'll never get my $ back from the camaro exhaust so I'll make it work with the truck. All this with trans shift upgrade which I'm not 100% sure yet as my research hasn't gone that far yet. I've never like gas mileage as it doesn't like me. I don't plan on towing anything above 32' boat more then 10-20 miles.
That SS silverado I had a 2.3 side mount whipple and full built FLT level 5 trans and 3k stall. It DID NOT like to tow. And reason why I sold it. ( I towed it once maybe twice about 10 miles). I knew a stall isn't good but truck I had before boat.
