Converting rollers to bunks
I'm sick and tired of the hull marks from my rollers. I think a boat should look just as good in the water as it does on the trailer. I plan on welding on a new rear crossmember and then adding the bunks. By my measurements the bunks will be about 8' long. I was thinking of doing a pair on each side of the hull. Then I will possibly add a keel roller to the trailer to protect everything.
BTW my trailer is an older Load Rite with the drop down rear cross member.
I have the trailer well balanced as it sits on the rollers. I will use those measurements for my height from the crossmembers. I will be changing the rear crossmember for sure, it hangs REALLY low and I don't want it to hang up on anything. I will make the crossmember with the boat still on the trailer and use that as a reference point and mockup.
