Trailer Tires
Old 09-10-2014 | 07:21 PM
Didnt read and just blabbin here...goodyear ht is a common trailer tire,,235/80/16..also carlisle makes a good american made trailer tire but make sure you check the dater codes on the tires sidewall..it will be on the sidewall close to the tire bead in a oval circle area on its own,,first 2 numbers are the month and the last 2 are the year made..
FIXX is offline
Old 07-07-2015 | 06:04 PM
bringing up an older thread but I'm in the same boat hahaha pun intended! With running a 15x6 dual axle setup 6K lb boat is it still ideal to run a LT tire in the 205/75R15 configuration or is that only for the 16"?
KRAUSMOTORSPORTS is offline
Old 07-07-2015 | 06:18 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
If I were you, I'd only consider 15" Maxxis ST tires; OR upgrade to 16" wheels/tires if possible.
Sydwayz is offline
Old 07-07-2015 | 06:23 PM
F-2 Speedy's Avatar
^^^^^ what he said, Maxxis
F-2 Speedy is offline
Old 07-07-2015 | 10:36 PM
Unfortunately I don't have 16" tires on my trailer and I don't know of any e rated truck tires in the 14" size. What is the best tire for us guys with 14" tires?
Revd Up is offline
Old 07-08-2015 | 12:35 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Maxxis as well, but stepping up to 15" rims would also be a wise move for you as well.
https://www.maxxis.com/trailer/trail...nflation-chart
Use the tire calculator here to get an idea of what you can fit:
http://www.1010tires.com/Tools/Tire-Size-Calculator
Modifying fenders to fit larger tires isn't usually a big deal on boat trailers as long as the fenders do not come close to interfering with the hull.
Sydwayz is offline
Old 07-08-2015 | 05:47 AM
I
Thanks Sydways! I saved the links for future reference as well!
Old 07-08-2015 | 06:50 AM
Very close, the first two numbers are the week, that the tires were built. The second two are the year. These will be the last 4 digits of the DOT code. If there are only three digits the first two digits are still the week, the last digit indicates the year in the 90's. Yes believe it or not we still see a lot of tires from the 90's on trailers, trucks, cars you name it.
Example 1514 would be the 15th week of 2014.
349 would be the 34th week of 1999.
Side note some years there are 53 weeks don't let that throw you for loop.
Questofpower is offline
