What if you
Old 10-22-2014 | 08:05 PM
Rookie's Avatar
Originally Posted by SB
Black RTV.
Red is actually better but won't match the tire well.
I'm pretty sure the Right Stuff was made for that application.
Rookie is offline
Old 10-22-2014 | 08:09 PM
Rookie's Avatar
As for the original question. I actually have a little hose Tee'd into my boats exhaust/muffler compressor. Lift the engine hatch pull out the hose. It's only 1/ 4" that is attached by Legris fittings so it takes up no room. It's convenient for topping off the tires when no compressor is around.
Rookie is offline
Old 10-22-2014 | 08:23 PM
Just rotate tire ..its only flat on the bottom , sheesh man easy fix errr what
paintman is offline
Old 10-22-2014 | 09:33 PM
Originally Posted by Rookie
As for the original question. I actually have a little hose Tee'd into my exhaust/muffler compressor. Lift the engine hatch pull out the hose. It's only 1/ 4" that is attached by Legris fittings so it takes up no room. It's convenient for topping off the tires when no compressor is around.
You do see the picture right?
ICDEDPPL is offline
Old 10-22-2014 | 10:19 PM
I like it. Also, it makes a great charging station for your device when doing brake job, bearing greasing, etc. Or, plug in that 12v mobile penis pump you have.
MILD THUNDER is offline
Old 10-22-2014 | 11:08 PM
12 v penis pump.
mike tkach is offline
Old 10-23-2014 | 05:15 AM
I'm thinking your avatar is distracting him from the obvious... BTW, nice work!
offshore312 is offline
Old 10-23-2014 | 07:06 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
I can change a tire quicker than a 12V compressor can re-inflate a flat.
Conversely, I have a coiled air hose off the compressor on my truck (for airbags and and train horns). I can reach the whole truck with it, and the spare mounted on the trailer. I also often carry a 5 gallon air can. Either option is quicker than a 12V K-Mart compressor.
Sydwayz is offline
Old 10-23-2014 | 10:14 AM
Rookie's Avatar
Yes, you wired a female cigarette adapter to your trailer. I guess I would have a problem if my boat wasn't on my trailer..
Rookie is offline
Old 10-23-2014 | 10:59 AM
Originally Posted by mike tkach
12 v penis pump.
I'd never leave the driveway if I had that set up.....
wannabe is offline
