Rental Truck with Tow Hitch
Old 02-11-2015, 05:55 PM
texaschopper's Avatar
Default Rental Truck with Tow Hitch
Does anyone have information on renting a large SUV or P/U with a tow hitch? I just called a few places such as Enterprise / Avis / Hertz and I am being told they don't have hitches and you cant tow. Enterprise has a truck rental division, but they don't do 1-way.
I was hoping to stay away form a U-Haul type deal as I am hoping for some comfort as I am going about 1500 miles.
Don't all P/U's come with a tow hitch receiver?
What's the average cost to have a hitch installed on say a Silverado, and perhaps I could just remove it when I am done?
texaschopper is offline
Old 02-11-2015, 08:51 PM
Triangle Car Rental is great, they rent 250's and 350's I towed my boat home with a 350 dually, BUT they only are in SE not FL
Pete280 is offline
Old 02-11-2015, 08:55 PM
I have been in your boat before and here is what I did. Find out what rental companies let you choose your rental. In Miami I know enterprise, thrifty, national and alamo let you choose which car you want. What I do is I go to the rental companies....walk around the lot and see what SUV has a hitch. When I find one, I jump online on my phone, rent and when I get a confirmation, I hold on to the keys and then go to the counter.
THIS MESSAGE WILL SELF DESTRUCT IN 30 SECONDS!!!
turbo rr is offline
Old 02-11-2015, 09:36 PM
Budget used to rent f250s with the provision for the large 2 5/16 ball on the bumper , wasnt politically correct but neither is the new rental car scam where customers are getting their eyeballs gouged out for "damage"that didnt purchase the supplemental insurance .reciever hitch is usually a stand alone option of part of a tow package youwill never see on a rental unit unless it was some kind of mistake that slipped through .the added comfort for me would be offset by the spinkter tightening fear of how hard they would try to insert it up my arse if the rental broke down or some bozo hit me while towing . And im bold . but that is now . Back then i did it all the time .was probably bolder.
airjunky is offline
Old 02-11-2015, 10:30 PM
Forum Regulator
Sydwayz's Avatar
Received 1,195 Likes on 519 Posts
Enterprise rents F150s and Ram 1500s. Most of them have a hitch. You should be able to go to your local Enterprise and lay eyes on the exact truck you will end up with.
All of the major rental car outfits specifically have bans on towing; but I've seen hitches on plenty of Tahoes and Expeditions, and the 1/2 ton trucks.
You can get a Class-III hitch for about $200 bucks and they install with 6-8 bolts in 30 minutes. That's all you are going to be capable to tow with a 1/2 ton platform anything, anyhow.
Some dealers rent trucks, but they would not be one way.
Also:
https://www.hertzequip.com/herc/rent...trucks+3.4-ton
I've rented an F350 from Triangle rent a car last year for a towing round trip. It was a great experience. I was hauling two PWC trailers rigged up like Sanford & Son in the back of the truck, while towing a tandem PWC trailer and two PWCs. I didn't want to risk scratching up my truck with that load.
Last, Royal rent a car used to rent PSD F250s, but I think they only do F150s now.
http://www.royalrentacar.com/VehiclesForRent.aspx
Sydwayz is offline
Old 02-12-2015, 04:50 AM
I suggest you try Hertz Industrial Equipment rentals. If you google it and go to a local location, they have a drop down menu with trucks. I did this a few years ago and rented a Chevy 3500 diesel with a 2 5/16th hitch.
No issues and I would do it again.
Good luck.
Apexwarrior is offline
Old 02-12-2015, 05:03 AM
weldcrane's Avatar
Hertz rent a h2 hummer they haves hitch I've towed before
weldcrane is offline
Old 02-12-2015, 06:23 AM
Quinlan's Avatar
Ryder has 1 ton Vans. I towed my 29 Outlaw w twins with a 3500 extended chevy van for a yr or so before I got a truck. Pulled and Stopped it no problem with trailer brakes.
Quinlan is offline
Old 02-12-2015, 08:13 AM
Thank you all for the input.
I am going from Scottsdale to N. Dallas so S. FL is out.
All I am towing is 12' U-Haul trailer so I doubt I would even eclipse 2500 lbs. I am liking Sydwayz' 200.00 hitch idea.
I am flying in so I cant go over and inspect the vehicles at the location beforehand. I am going to check out a couple local places here today and see if they all have hitches on their trucks with the thinking the trucks in AZ will be the same- maybe I will get lucky.
Old 02-12-2015, 08:26 AM
lightspeed's Avatar
almost all the yukons and tahoes have hitches installed on them u have to take off the center cover and theres the hitch when your done snap the cover back on i have done that a bunch of times,,just dont tell em your towing with it
lightspeed is offline
