C5-C6 Corvettes...
Old 08-20-2015 | 08:43 AM
  #91
offshoredrillin's Avatar
boy that sure is a diff car than the one I unloaded from the trailer... awesomeness!
offshoredrillin is offline
Old 08-20-2015 | 10:07 AM
  #92
Quinlan's Avatar
That needs to be posted in the Dry Pipes post. Sounds Sweeeeet!
Quinlan is offline
Old 08-20-2015 | 05:31 PM
  #93
Sydwayz's Avatar
Forum Regulator
Originally Posted by TooLateVTEC
Sounds good Brian, what did it make for power? Those exhaust tips are cool looking.
You did heads/cam/intake right?
That, and a few other little things including injectors and a fair amount of dyno time.
These cars are spot on 15% for parasitic loss, which calculates to 541HP at the crank with these dyno numbers at the wheels:
[ATTACH=CONFIG]544444[/ATTACH]
Attached Thumbnails C5-C6 Corvettes...-80-unnamed_0091bac6db4582c328a75def81544b28ef1e6b94.jpg
Sydwayz is offline
Old 08-27-2015 | 07:32 PM
  #94
lucky strike's Avatar
Originally Posted by lucky strike
We are taking in on trade a 2007- ZO6 Black/ Black. with 10,000 miles. 2-LZ with Nav.
The customer bought it when it was a year old.
Ck our website.. www.mercedeshowroom.com. for pics. Coming soon.
Coming in Tuesday, a 2008 Yellow ZO6 with 5400 miles. 2LZ with nav.
lucky strike is offline
Old 08-27-2015 | 08:00 PM
  #95
Good looking car. Here is my z.
indysupra is offline
Old 09-05-2015 | 07:16 PM
  #96
Sydwayz's Avatar
Forum Regulator
Found out tonight that it's time for a clutch! Stock isn't cutting it anymore.
Sydwayz is offline
Old 09-06-2015 | 06:50 AM
  #97
Did it slip or did the slave stick?
Old 09-06-2015 | 07:47 AM
  #98
Sydwayz's Avatar
Forum Regulator
It slipped twice last evening.
Once on a mild into-2nd at a stoplight.
Once on a hard into-2nd after spinning tire on 1st launch.
Sydwayz is offline
Old 09-06-2015 | 07:58 AM
  #99
Bunmer. I Have an aluminum fidanza and an ls7 clutch in mine. It's ok but if I was to do it over again I would do a dual plate McLeod.
Old 09-06-2015 | 08:04 AM
  #100
Sydwayz's Avatar
Forum Regulator
Good to know, thanks for that!
Sydwayz is offline
