Getting closer!
I also bought this while I was out there:
78 Dodge 318 3 speed on the tree Manual steering Manual brakes Radio delete. Not one spec of rust anywhere. I had to leave it at a storage yard in Barstow because the Ramcharger was on the trailer. I flew out to Ontario 3 weeks later, took a Bus to Barstow and drove it home. It was sold before I even flew back out there... The stuff in Hesperia and Barstow is unbelievable and cheap I paid 1200$ for the truck and 4500 for the Ramcharger. You can park stuff out there, and 20 years later and the only thing that happened is the seats got cooked and the paint faded. If you look at the 78 the grey spot on the door is where the mirror reflected the sun and cooked the paint right off.
No Just to a 2500. The frame mounting points are the same so I just put new bushings, balljoints, tier rods etc on the arms and knuckles from the donor truck.
4 WD would pose a few problems, mainly the fuel tank is right where the transfer case would need to go. I could do a passenger side drop transfer case, and an early Dodge or Chevy Dana 60, but then I'd run into ABS and steering issues along with figuring out how to mount a track bar on a passenger side drop front axle. Anyways I have a Ram Quad Cab Short bed V-10 4WD and a Wrangler.
The Ram has been stuck in body shop hell for 3 years, and the Wrangler is still running and driving, but I'm collecting parts to stretch it into an Unlimited with a 5.9 Magnum V8. That will be resumed when my 27 Magnum is finished (Yeah I have a project problem... I also have a 1953 Plymouth Wagon at another body shop, and a 1970 Plymouth Sattelite shell that will become a Superbird Clone someday)
