Vehicle Recommendation Please
Old 05-12-2016 | 08:24 AM
Originally Posted by techman
Agreed, any GM with the 8.1 and 4.10 rear end. Suburban, Yukon XL, Sierra 2500, Silverado 2500, Avalanche 2500.
Having moved from an 03 Avalanche 2500 with 8.1/4.10 rear truck to a 2015 Silverado 1500, my new silverado out tows, out brakes, out accelerates, has less rear end sag, and more stability that my Avalanche ever had. My avalanche was in great mechanical condition and even had the motor putting out 370 hp. My silverado cheap lease truck beats it in every way. I can't believe how the new 1500's are better than the old early 2000's 2500 trucks. I couldn't buy a cheap old rusty 2500 for what I pay a month for this lease. I was very skeptical at first.
Gimme Fuel is offline
Old 05-14-2016 | 10:57 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Are you towing a 380 Powerquest Avenger with a 2015 Silverado 1500?
Sydwayz is offline
Old 05-14-2016 | 11:05 PM
My 2007 2500HD CC 8.1/allison tows my 32 AT easily. I figure I'm at 11-12k depending on gear and fuel load.
The 8.1 Suburban does not get the allison trans, but it will still be fine with a 272 Formula.
Griff is offline
Old 05-14-2016 | 11:24 PM
bck's Avatar
bck
Charter Member#568
This is something I've been curious about. I don't have the exact specs but I believe my old 3/4 ton was probably rated to tow about 10 .5 k. If you check the right boxes I think a new half ton can tow as much or more. So what has changed to allow a new 1/2 to tow more than an older 3/4? I'm guessing the situation is the same with cargo capacity but haven't actually checked.
Straight bottoms and flat decks
bck is offline
Old 05-15-2016 | 01:54 AM
Originally Posted by scottgjerdingen
Is it possible to get a viable10K lb tow vehicle for under $8K (less is better, this vehicle will only be used for towing ~ 5 times a year)?
10K lb may be an overstatement of need, I will be towing a formula 272 sr-1 which I believe is ~ 6K dry and it will sit on a tri axel trailer having brakes on 2 axels. So all loaded up and playing it safe I am calling it 10K but in actuality it may be less?
Only requirements for this vehicle are cost and safety/reliability (and it must be able to do highway speeds). If possible, what sort of vehicle/vintage should I be looking for?
Thanks!
Why not just rent a truck? Some Ford dealers rent everything from F150s to F450s. I suspect you would never spend the 8K in rent, nevermind maintenance/insurance/tag fees.
Jupiter Sunsation is offline
Old 05-16-2016 | 10:06 PM
This is my current/contingency plan. A bonus with this is one less vehicle to storage. I can however always rationalize the need for one more vehicle, besides a single purpose of towing a boat, it would be handy with the home depot runs, the occasional inclement weather and transporting larger groups of people (or my new puppy that will be growing to over 200 lb ....soon he won't fit in the 550)
scottgjerdingen is offline
Old 05-17-2016 | 07:02 AM
For a half mile between the marina dry storage barn and the ramp.
Old 05-20-2016 | 09:17 AM
RollWithIt's Avatar
There are a lot of older dually trucks out there that would probably fit your bill. Sometimes people will dump the prices on used duallies because there is a smaller market for them outside of jobsites because they are not good daily drivers. They might not be the prettiest to look at in that price range but will get the job done if mechanically sound. I would look at older diesel trucks for towing. Especially if they have a lower axle ratio. Might be able to get a better price by buying an older work truck or cab and chassis combo, then you just need to get a traditional bed if you want.
RollWithIt is offline
Old 05-20-2016 | 09:22 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
I assume you have EoH brakes, else I'd worry about the boat dragging the truck down the ramp.
No brakes on this setup. I like taking risks.
[ATTACH=CONFIG]555756[/ATTACH]
Sydwayz is offline
Old 05-20-2016 | 09:24 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
+1
But I don't think you are going to want to shop locally. They are all going to be so rusted out, that they will be sketchy for towing. I'd look for Arizona, Nevada, or Texas trucks.
Sydwayz is offline
