Ford Triton spark plug issues??
Old 01-20-2017 | 11:16 AM
Originally Posted by paintman
OK ..You guys made me by in lol...And last question..The battery was dead so they boosted it and it blew the fuse that controls window and dash lights..Was it just to much juice for whatever reason or is there another issue. Truck was sitting for a bit hence the dead battery. Thanks fellas
Not sure how the fuse for the windows and dash lights are affected by jump starting the car. There should only be current going through the fuse if the window or lights are operating. Even then, when starting the car, the starter has priority so those items should be getting less power when cranking. Either way, the first thing is to replace the fuse and see if everything works and if it blows the fuse again. If it blows the fuse again, then theres a lot more investigating that needs to be done.
ToMorrow44 is offline
Old 01-20-2017 | 05:31 PM
Maybe you need a truck without spark plugs.
Pol83x is offline
Old 01-20-2017 | 06:25 PM
And...... Now you need an alternator too.
Keith Atlanta is offline
Old 01-21-2017 | 10:44 AM
Lol...That would be a Tesla?? But I've heard they have waaayyyyyy to many issues...Biggest thing I heard was loose muffler belts
QUOTE=Pol83x;4521481]Maybe you need a truck without spark plugs.[/QUOTE]
paintman is offline
Old 01-21-2017 | 12:16 PM
No that would be a diesel
Pol83x is offline
Old 01-21-2017 | 01:27 PM
And once you get the plugs changed.....
[ATTACH=CONFIG]563990[/ATTACH]
phragle is offline
Old 01-21-2017 | 01:59 PM
My dad has a 2000, 220k miles on a 4.6L. Make sure you do a fuel induction service before you change the plugs, it brakes up the carbon in the heads, thats what causes the spark plugs to seize up and break.
THACAMAROKID69 is offline
Old 01-21-2017 | 04:05 PM
Back in the day of carburetors we used to take a quart of warm water, hold throttle wide open and dump it in fast as she would take it to clean up the chambers. Actually worked pretty good.
Pol83x is offline
Old 01-22-2017 | 11:20 AM
Glow plugs spark plugs same thing...
paintman is offline
Old 01-22-2017 | 11:36 AM
The dash and window fuse probably blew before the jumpers were attached. Low voltage, amperage went up, someone tried more than one window at once and pop goes the fuse. No biggie. I've had 6 or 7 super duty trucks. Great platform, 5.4 is no powerhouse but it won't let you down either.
Unlimited jd is offline
