Bearing grease
So, I got an answer from Myco and it was what I had suspected. Myco trailers (mine included) as of 2006 have air-tight hubs; no water or other contaminants enter the hub chamber so the grease remains sealed within the hub and cannot wash out. Makes sense. For non-airtight hubs, other products might be better.
While we're on the subject, I also have one of these:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
It ain't cheap but was a life-saver having to pack 12 bearings and fill hubs.
I would assume so, but another poster was talking about "wash out". Myco uses an "air-tight" hub, that has a special bushing on the axle, a viton grease seal on the rear of the hub and a rubber diaphragm on the grease cap that allows the hub to be pressurized with air to keep everything out. The grease seal and the grease cap are also coated with a bonding agent prior to being pressed into the hub to maintain the air pressure.
Yeah, I know. The Dewalt has a variable speed trigger; allows a slow and steady pump. Takes a while but a hell of lot easier than pumping that grease gun handle a few hundred times.
This one ?
Schaeffer Manufacturing Co. 02212-029S Moly Ultra Grease NLGI #2, 14 oz.
Link: http://a.co/goKyckj
I ask because if you scroll down it looks like they offer a handful of other types too.
