1995 Ford 250 7.3 Powerstoke
I have a bad leak dripping at the back of the engine where the rear main seal is. The rear main seal is not linking and it is leaking both fuel and oil both cant figuer this one out if someone could help me I'd greatly appreciate it
Originally Posted by Clayton55
(Post 4641807)
The fuel filter bowl orings and mechanical fuel pump assembly (two stage) are the #1 and #2 causes of fuel leaks in the valley.
There are several places that supply a oring kit (diesel orings comes to mind)......just dont attempt ford.......they want you to buy the entire bowl assembly. The water sensor in the bottom of the bowl will drip too..........replace it when you do the bowl orings along with the rubber hoses. If it does end up being the fuel pump.........dont believe the clowns that say you have to remove the turbo......100% not true.......You may have to slightly modifiy a 1.25 inch wrench (I was lucky, mine was thin enough an clocked just right) |
| All times are GMT -5. The time now is 09:18 AM. |
