Lifting points for cradles, 1988 F311 SR-1
My boat lift installer is looking for a point-of-reference for the main lifting point (center of gravity?) to set the cradles for my 1988 Formula 311 SR-1 with twin big blocks and Bravo drives. Can anyone help?
Thanks, Tom Ps-he's estimating about 3' forward of the transom (not including swim platform). |
Look at it's position on the trailer if you have one. On a triple axle is should be somewhere near the center wheel centerline, maybe slightly to the rear of the C/L. Three feet forward of the transom seems a little too short.
Originally Posted by ren3
(Post 4733918)
Like your trailer, the lift bunks should be extended to the transom so the bottom does not develop a hook due to the weight of the engines putting pressure on the unsupported ttransom. Hopefully a boat lift expert will weigh in.
(Post 4733939)
Formula should have a drawing to show the support points. Call them to get a copy.
Originally Posted by Helmwurst
(Post 4735618)
| All times are GMT -5. The time now is 10:57 PM. |
