Trailer tire pressure in the heat >
Old 06-15-2021 | 01:12 PM
F-2 Speedy's Avatar
Default Trailer tire pressure in the heat
My trailer tires say max cold 80psi they are Firestone Transforce, in this heat pulling should we back them down a bit ? thoughts
TIA
Speedy
F-2 Speedy is offline
Old 06-15-2021 | 02:45 PM
bajaholic's Avatar
Keep them at max. The lower the pressure the more they heat up.
bajaholic is offline
Old 06-15-2021 | 02:50 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Yep. Inflate them to max tire pressure when cold.
I also recommend:
https://www.tireminder.com/
Sydwayz is offline
Old 06-15-2021 | 03:22 PM
Veteran: Navy
I set my tire pressure 2-4 PSI below Max. All according to the ambient temperature out side.. I have the same tires
AmiableDave is offline
Old 06-15-2021 | 03:26 PM
F-2 Speedy's Avatar
OK now Im more confused ..............it will be in the 90's trailering to LOTO tomorrow
Old 06-15-2021 | 03:49 PM
Set the psi at the temperature you will be running in. 90* day, set to 80. 50* day, set to 80*.
underpsi68 is offline
Old 06-15-2021 | 04:39 PM
I always run about 5 psi less (checking cold) than max recommended...in other words, my tires say 60 psi max so I put 55 psi in them before starting a trip.
Baja 252 Islander
bajaman is offline
Old 06-15-2021 | 05:11 PM
I put in 75psi instead of 80 when it`s going to be hot as balls
btw the automatic tire inflator sydewayze recommended is the $hit!
deflated and inflated automatically .
ICDEDPPL is offline
Old 06-15-2021 | 05:19 PM
jeff32's Avatar
same here... 4-5 psi less than max, and constantly laser check tire temp when stopping,,, and they never go higher than 110-115... bearing around 125-130
never had a problem !
jeff32 is offline
Old 06-15-2021 | 05:46 PM
Cold pressure means they haven’t been run or heated up. Has nothing to do with ambient temperature. I E in the drive way or shop fixing to head out. Havnt been used.
Eddienel is offline
